Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Manual release on door lock of a bosch nexxt series 100 washer
Manual release for the door lock? drained the tub but no power to control panel.
Try pulling door up before out. My washer does this when the rubber around the door gets a piece of wet paper under it, or I have overloaded it and the rubber gets moved. Once open, run your fingers around the rubber seal to verify nothing under it and that it lays smooth.
Posted on Jan 03, 2013
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
  • 3 Answers
SOURCE: We have a Bosch Nexxt 100 Series Washer. The door
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Posted on Feb 04, 2011
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
Mar 07, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Door will not lock
Possible that the door lock is jammed or there is no trigger from the door switch or lock. Also this can be due to fault in the control panel, check the input/outputs from the controller unit.
Click this link: door lock
Jan 21, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
Jan 02, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer will not drain water out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Pl rate me nice if helped, thanks.
May 12, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 100 series will not drain
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
BOSCH washer, the door won't unlock and is reading E:04
I used a thin screw to release the lock through the access hole and this released it after rotating the round panel a bit. The manual release on my Bosch is a nylon deal that hangs down from the top. Just pull down lightly and open door. You may have to reach up past the drain to get a hold of the nylon string. The access opening is fairly sharp.
Dec 05, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
118 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
