Question about Hannspree HANNS-G 19" Widescreen Monitor
Screen i bought a Hannspree monitor to hook up to my laptop because my laptop screen went out when i first tried it it worked fine i turned my laptop off when i went back to get on it started loading fine the toshiba screen poped up then the windows screen then it jumps to a screen thats says no signal input/check video cable PLEASEEEEEE HELP
    Sergeant:
    Champion:
  • 318 Answers
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Posted on Jan 19, 2009
Old LCD monitor detected by but not getting a signal from AMD-run desktop
start in safe mode press f8 on power up go to control panel and go to display control panel varies on operating system screen resolution & frequency to high set at 800 x 600 resolution at 60 hz and you may get a picture
May 22, 2014 | Hannspree Hsg1106 20-inch Widescreen Lcd...
Cannot get it to connect to monitor
Hi, What model Hannspree is it? you might have the resolution set too high for the monitor!
Sep 23, 2007 | Sony Playstation 3 (PS3) Console
I'm trying to link my laptop to my hannspree monitor to view a dvd. how is this done?
The exact process varies by make and model of your laptop, I will give you the "generic" hookup instructions, if you get stuck at any point simply reply back with the make and model of your laptop and the exact model # of the Hannspree and I can give you more specific instructions.
First you need to identify which video out ports you have on the laptop, most current models have VGA which has 15 pins in three rows of five, these carry video only. Many current models also have HDMI outputs which can carry audio and video. Now check the Hannspree and see which options it has. Identify one of the port types which is available on both the laptop and the monitor.
Once you've identified which ports will work hook up a cable between them and turn on the monitor. As far as I'm aware the Hannspree should switch to the chosen input so long as nothing else is hooked to the monitor. Now look at the bottom left portion of your keyboard, there should be an "Fn" key. This works like a Shift key only it activates the pictographs on some of your keys. Depending on the brand the "Fn" key can be one of many colours.
Whatever colour it is, look through the pictures on your F-Keys(the top row), depending on brand you should see , "crt/lcd" a picture of 2 monitors or a single box with a line on either side. Hold the Fn key down and while holding it, press the F-Key you found with one of the monitor symbols. Depending on the brand this will either cycle between laptop, external or both or it will bring a menu up on the laptop screen offering options.
Once you've set it to external or both monitors, if the hannspree isn't showing and image check the manual or reply back with the model number and I can help you figure out how to switch inputs on the monitor.
Hope this helps FixYa,
Chris
Jan 01, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
No picture - only "Adjusting" message flashing/floating on screen
your LCD panel is fried!! those flat screens are notorious for that
Jan 14, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
I tried to hook up my ps3 to my hannspree monitor
did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
Oct 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Dim screen ruining my Hannspree
your LCD screen backlite bulbs are bad or the inverter card the drives them is going bad
Oct 02, 2009 | Computers & Internet
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Hannspree HF289H Monitor going white
IN THE MENU TRY EITHER COLOR CONVERSION OR DEGAUSS,,OPTIONS ,,CUOLD BE A BAD VGA CALE ,,ALSO TRY DOWNLOADIND A NEW DRIVER
Apr 20, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HANNS-G 19" Widescreen Monitor Logo
422 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
