Question about Sony MHC-MG510AV Shelf System
MHC-MG510AV...Power Failure... I have seen and read most of the other reviews on here...i wanted to try and fix the problem myself...but i doubt that will happen...as mentioned, my system is broken...twice it reacted this way in about two weeks...the screen was jammed and frozen...and nothing worked..I unplugged and plugged back into the wall and both times it rebooted, the final time the power light is on and red...but no screen "demo" appears and nothing works...i'm looking for directions to fix it...or somewhere locally to fix it..or determining whether its worth my time too fix...its been a great stereo but it might be out-dated. Who should i seek advice from locally that wont charge me a "butt-load" to fix the stereo??? Any suggestions comments, continuations...please get back to me...Thanks All!! pthora83@hotmail.com
  • lakegirl99 Oct 04, 2008
    Ditto.....I can't find anything on how to fix the problem. I've checked everything out and can't find what's causing this.
Fuse keep blowing after crossing speaker wires.
Fuses blow when there is an overload. In your case when you crossed the speaker wires you shorted the main amp. This now has a part that is acting just like a strand of wire.
Trace back the channel you crossed the wires and find the main output device(s). Then replace them. They will be located on a heat sink if that helps.
Jul 03, 2017 | Sony MHC-MG510AV Shelf System
My MHC-GX450 worked fine for several years. I just went on vacation for two weeks and before I left, I unplugged it so lightning would not cause power surge damage. When I came home and powered up, it...
After calling SONY support, they wanted me to send the entire system - speakers, cables... Please! That's is dumb, and the rep had to be reading it from a script.
So I managed to get the covers off and figured it out on my own. The drive belt for the CD tray had come off the pulleys. I simply put it back on and... Voila! Saved myself hundreds of dollars for a $2 belt. I called SONY and ordered two spares. Sometimes, if you have some mechanical and basic electrical skills you can save yourself a lot of money and aggravation.
Sep 22, 2011 | Sony MHC-GX450 CD Shelf System
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
Sony mini hifi MHC w28d showing reading but no playing
You player is not detecting the data stored in the disc. this is due to many issues, but firstly let us first clean the optical head either using a lenns cleaner- good one- or by using a good sway gently on the lens.it this wont work, open the system and check the drives. if the cd rotates but fails to read you have a defective/ weak optical system. you will need to replace the head. Further if you can check for the RF in the optical, absence means failure. Also the main board/ processor could be defective. All this can idicate the same fault of no reading / playing. However if the reading is seen but there is no output then check for the speaker outputs/ speakers. check for audio out for signals. if present then the output audio amplifier is defective. check this out. Good day.
Jul 12, 2010 | Sony Audio Players & Recorders
Sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Feb 15, 2010 | Sony MHC-GX450 CD Shelf System
I want to unlock my nokia phone myself
Are you talking about the PUK? If so, please review this article: http://en.wikipedia.org/wiki/PUK_code
Then call your service provider.
Failure to read and follow the guidance in the reference may render your phone useless.
Feb 14, 2010 | Nokia 1600 Cellular Phone
Sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
Zenith dvd/vcr mod #6711R1N211C. Need to prog the volume button.
In my manual, to control a sony TV.. the code is number 8 or number 9.
You will hold down TV POWER, hit 8 then release TV POWER.
If that doesn't work, try number 9. Once the batteries are removed, it resets the code, so write it down. It will also over ride your old codes once you input the new one.
Note: Depending on your TV, some or all buttons may not function on the TV, even after entering the correct manufacturer code.
I looked for the section on Stereo, but all I found was the above.
Hope this helps.
Nov 22, 2008 | Zenith XBR411 DVD Recorder/VCR
Sony MHC-MG510AV Shelf System Logo
52 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
