Question about Xerox Phaser 8500/DN Printer
Dear Sir, We have a Fujixerox Docuprint C2100 and we have a message error about our tray1. We try to print using tray1 (have paper inside) but the printer request paper.
    Scholar:
  • 49 Answers
I would remove the tray from the machine and all paper from that tray. Then turn it over and make sure and make sure that the paper slides are working correctly. The machine doesn't actually detect the paper just the fact that you have the paper slides up against it. So after you have put the tray back in the machine make sure the paper slides are firm up against the paper and it should be fine.
Also, while the tray is out of the machine make sure there is nothing in behind the tray blocking the sensors.
Posted on Mar 30, 2009
How do i fix my fujixerox docuprint p2515. It keeps blinking red and cant print anything.
It likely is also flashing an error code. We can help you if you post the error code.
Jun 02, 2015 | Office Equipment & Supplies
Boot printer 116-324
The file you sent to printer is broken/damaged. Clean out the print queue. Draw the network plug off the printer. Reboot printer.
It may also be a broken pdf by Adobe Acrobat. Use another for instance Foxit Reader and try to print out by that program.
Jun 24, 2014 | Xerox DocuPrint C2100 Laser Printer
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
I have just upgraded my PC to iCore 7 with Windows 7 64bit OS, however when printing to Fuji Xerox Docuprint C2100, the gradiation on the photo is pixelated and not smooth. What printer settings do you...
Did you use plug and play or did you follow the install programs' directions? If you use plug and play, many features do not work.
If you did plug and play, uninstall the printer, download the current install program from Xerox (free), presuming they make one... Some printers and lots more scanners do not work with newer OS...
THEN, use the interfact that Xerox (likely) provides, to run the printer.
Newer printeres and scanners are now NETWORK based, meaning non hosted by a computer. You have to run installs on the printer AND every machine, but then anyone can scan, for example, as if they hosted the scanner.....
Feb 23, 2011 | Xerox DocuPrint C2100 Laser Printer
FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Jan 05, 2010 | Fuji DocuPrint C1110B Laser Printer
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
I have problems printing from my computer to my printer - Printer Error Message
It sounds like the default tray it's expecting to pull paper from is out of paper.  Make sure the trays have paper, and that it isn't jammed.
Nov 06, 2008 | Canon imageCLASS C2100 Laser Printer
Xerox Phaser  8500/DN Printer Logo
177 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
