Question about Exercise & Fitness
E2 Error code on Hyperextension treadmill
Display works has power press stare E2 comes up will not run
SOURCE: I just put a new belt on my Pro-Form treadmill.
Hi there
sanjay treadmill repair professional from india
you have done some mistake when you fixed the new belt.
You have a speed sensor problem.
CHECK
1.Front roller sensor usually a magnetic one for broken wire or for larger space between the magnet and the sensor.
i) Sensor is Usually 2 wire and magnet is fixed on to the roller.
ii) Magnet can dislocate from its place check the magnet for attraction by taking a screw driver.
iii) Chcec gap between the magnet and the sensor on the frame. Gap should be betwwen 3mm to 5mm.
2. If roller sensor is not present then there is alternative sensor on the motor ususlly a multi holed plate revolves between the sensor.
i) It is usually has 3 wires.
Check for the connections on the motor control board.
If not solved then mail me on sanjay_phil@yahoo.co.in
Posted on Oct 02, 2009
SOURCE: E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Posted on Oct 14, 2009
maxtreadmill
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
E2 comes up on my treadmill unplugged it a few times runs for about 30 seconds but e2 code comes on again what can we do
Try to check the speed sensor position. also check is there is any dust accumulated on it
If you wish to get some details about treadmill error codes and solution ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 05, 2017 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Hyperextension jn-1360 type h 6136004 error Er o2 comes up after 20 sec running and then stops
1) Adjust the speed sensor see the diagram, clean it, and tight the connector very well.
2) test the input voltage motor, if there are the motor need repair,se my personal TIPS
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block
4) Run the software caibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 20, 2012 | Bh Fitness T8 Basic Treadmill
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
Exercise & Fitness Logo
125 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
