Question about True GDM-26 Refrigerator
Gdm-26 beverage cooler light not coming on
4 Suggested Answers
SOURCE: True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's overload or capacitor may be out.
Posted on Sep 13, 2008
  • 7 Answers
SOURCE: We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Posted on Aug 13, 2009
  • 10 Answers
SOURCE: I have a True GDM-26. The contents get cool
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Posted on Apr 17, 2010
True GDM-10 cooling problems
Turn thermostat to a higher number or replace it.
Dec 18, 2012 | True GDM-9 Beverage Cooler
Setting are set on 9 and my drinks are still exploding.
Possible that the thermostat control is not reacting to the setting.
so you must check if there is any break or replace the unit.
Sep 13, 2010 | True GDM-7 Beverage Cooler
My drinks keep exploding
You need to turn the thermostat up ....the drinks are frezzing and that explodes them...
heatman101
It is building pressure but is not cooling and condensor fans aren't pushing much air.
If you are sure that the condenser is not flowing much air, it is probably clogged. Make sure you can see all the way thru it. Use a flashlight and see if you can see light thru it.
Jun 22, 2010 | True GDM-9 Beverage Cooler
Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
May 20, 2009 | True GDM-7 Beverage Cooler
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
Beverage cooler not cooling enought
Jeremy, after the line and new filter drier is put in the high pressure side and silver soldered make sure the unit is placed in absolute vacuum for 30 to 60 minutes. It's critical that all air and moisture is remove and the charge applied on low side with out a single air bubble put back in. You may need some on hands help on this solution to get the cooler working properly, Thanks Sea Breeze
Oct 27, 2007 | True GDM-7 Beverage Cooler
True GDM-26 Refrigerator Logo
27 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
