Question about Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator
Frigidare gallery freezer handle loose
Bottom freezer door handle loose. how to tighten
5 Suggested Answers
  • 29 Answers
SOURCE: refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Posted on Aug 13, 2008
mohammed387
  • 1952 Answers
SOURCE: FRIGIDARE FRS26ZSEB: Freezer side, bottom
If the water is running down into the refrigerator section, This usually means the drain is blocked. Look in lower section at the top center ( you may have to remove control panel to get access) remove the drain cup gentle with screw driver from each side, clean , from under unit at the back locate the drainage tube, having someone holding paper towel from were you removed the drain cup blow into the tube to clear any blockage that might be in tube, re-install drain cup.
This should clear water leakage problem. 2) Icemaker You may have 1 or a couple problems here. First problem may be the water valve may not be closing fully allowing a small amount of water to continually leak into the icemaker.
Solution Replace water valve
Second; The problem may also be with the freezers defrost thermostat, If this is the problem though it usually means your food is also freezer burnt, Means the unit when in the defrost cycle is staying on to long allowing to much heat to be generated in the freezer compartment.
Solution: Replace the defrost therostat
Posted on Sep 14, 2008
  • 108 Answers
SOURCE: freezer door handle is loose
Usually those handles push directly up to come off the pegs. You really have to "lean in" to push the handle against the door and then try to slide it up. Once you get it off, you can tighten the studs (or whatever hook/clip thingy they came up with) and slide it back on.
Posted on Feb 10, 2010
  • 884 Answers
SOURCE: my frigidare refrigerator has a freezer on top but the fridge door has dropped it is a newer frigidare how do I fix
The bottom hinge needs slackening off, lift the edge of the door in place and retighten the hinge screws; if it's not that loose, a sharp tap with the heel of your hand may bring it back into line
Posted on Apr 24, 2012
My frigidare refrigerator has a freezer on top but the fridge door has dropped it is a newer frigidare how do I fix
Apr 24, 2012 | Frigidaire Refrigerators
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Logo
20 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
