Question about Palm Apex DVD Player AD-500WM
My apexAD-500w dvd wont play dvds,but will play the cleaning cd
I put a dvd in and it just spin then says 'no disc'
  • bladysha Jan 19, 2009
    it plays my cleansing dvd
  • 11,896 Answers
You need to blow on the lens inside. It may be dusty. Unless you have a can of airduster.
If the lens is good it will work. If it doesn't work then the motor inside is bad
Posted on Jan 19, 2009
  • Nate Stansfield
    Nate Stansfield Jan 19, 2009
    Well it is a good sign that the cleaning cd works. However, the cleaning cd might not be doing it's job.
    I would take the top cover off the player and take a Q-tip and rubbing
    alcohol and wipe the lazer lens. After it is dry, try playing a dvd
    with the cover off and see what happens. Take notice of the lens while
    it is trying to play your dvd. Does it slightly wiggle back and forth
    and then doesn't read? If it does, then It is misaligned/untuned due to
    an electronical problem.
    Tell me how cleaning the lens and then playing dvd goes.
My Dynex DVD TV plays some DVDs and on other ones will spin like it is reading then stop and read, no Disc. I have cleaned the lens several times, but still will not play certain DVDs that it use to...
Hi, Did you also clean the disc's of dirt and finger prints. There are some discs that you will not be able to play. Ones that were made on certain computers.(format) In the manual it will list all dvd's you can play. even music CD's Good luck.
Feb 21, 2015 | Dynex Televison & Video
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
I put a dvd in but the system is not reading it. i've tried other dvds and tried all 5 disc changers, but my system is still not reading any dvds. what is wrong?
Hi, what makes the DVD not to be able to read the inserted DVD's is because the lens of the player is too weak to spin the dvd plate to play.
You will need to use a DVD Lens cleaner to clean up the lens inside the player to clean up dirt disturbing it from not playing any DVD cd.
If after cleaning the Lens and still does not play,you will need to replace the Lens..
Have a nice day..
Feb 18, 2011 | Panasonic Home Theater System System
Cd drive not playing cds or dvds
Sadly if you have tried a number of CD's in this (I'm assuming its a DVD/CDRW drive), then the drive may be broken. If it spins the disc up when you put it in and there are no rattles (indicating a worn bearing), you could try a DVD cleaning disc which will clean the laser lens, which might help, but depending on how old the drive is, there is a chance it is simply worn out
Dec 30, 2010 | Compaq (120192-B21) CD-ROM Drive
Disc wont play
you have to clean the lense using the cd-dvd cleaner disc
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
Compaq presario 700us will play cds wont play dvds
Try to put your laptop always on flat surface. Uneven base gives angle to the already tiny clearance space for the disc. Could be that the DVD disc run coz its finer, it will spin much slower than CD disc.
Hope i give you some good observation.
Mar 29, 2009 | HP Compaq Presario 700, 700A, 700AP,...
It wont play dvds!!! Help!!! Panasonic SC-HT520
You can try a CD/DVD Cleaner Disk ($3-$5). Some sell for $15, don't know if you'll get better results. If it doesn't work, then you have a laser alignment issue that needs calibrating. The labor is likely to cost more than a new DVD player.
Dec 28, 2008 | Panasonic SC-HT520 System
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Palm Apex DVD Player AD-500WM Logo
177 people viewed this question
Top Palm Televison & Video Experts
Are you a Palm Televison and Video Expert? Answer questions, earn points and help others
