Question about NEC MultiSync MT830 Multimedia Projector
Problem with NEC Multisync MT830
I have a hand me down MT830 that i recently tried to get to work and i ran into some problems. When i turn the projector on, it displays the first set of options perfectly clear (video, s video, rgb, ect.), however it shuts off almost automatically within about 4-5 seconds. Can someone please help me out, im pretty much just looking for a quick fix, so if anyone can help that would be great. thank you justin
  • 32 Answers
Check to see if the fan is running on the bottom of the unit. If it senses no rpm from the fan, if will shut down to protect the unit.
Posted on Mar 16, 2008
If you are tech savvy in the slightest, open the unit up. check to see if all contacts are intact. This sounds like a thermostat error. Make sure the thermostat and the ballast don't have any loose wires. If it isn't connected properly the unit will think it's overheating and shut down.
Hope this is somewhat helpful.
Posted on Sep 28, 2008
    Problem Solver:
  • 3 Answers
May be you set on auto power on if there is the video sinal need or it will turn off by it self good luck.
Posted on May 01, 2008
Hey. if i dont have the remote for this am i pretty much just screwed?
Posted on Aug 29, 2008
NEC Multisync LCD1765: Screen flashes and then mintor turns off with message "No Signal"
Restart your computer.
As soon as it starts the start-up process, keep tapping the F8 key, repeatedly.
When you see the Windows "start-up" menu, select "start in safe mode".
Does your monitor work in this low-resolution (640-by-480 or 800-by-600) mode?
If so, then you had configured Windows to a too-high resolution that the NEC did not support.
Choose 1024-by-768, and click "Apply", to test that the NEC supports this mode.
Try connecting the NEC to some other computer, to see if the NEC itself is the problem.
Mar 28, 2011 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Need the projector bulb where can i get it and how much multisync mt830
Hello I am an electronics technician from Washington,DC. Try projectorzone.com they are located in Portland,Oregon I have used them several times. Nate was very helpful. You can find a lamp there for sure.
Nov 19, 2010 | NEC MultiSync MT830 Multimedia Projector
Screen off center
try updating the latest driver for your video and bios. try connecting your laptop to external monitor
if both of this didnt solve your problem, i suspected you lcd screen is faulty and need to replace.
May 29, 2009 | NEC MultiSync XE21 (White) 21 in.CRT...
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Nec mt 1000
go to menu- go to setting -go to colour move slider to right hand direction befor you change the lamp -take care that some vga cabel(((cabel between pc and projector make this fault).then you have to change this cabel and try.
Mar 09, 2008 | NEC MultiSync MT830 Multimedia Projector
NEC Projector
they have a fuse on the power board inside the projector itself, But normally the fuse does not go bad unless their is a dead short in the unit.
Dec 13, 2007 | NEC MultiSync MT830 Multimedia Projector
Double vision-without viewing under the influence
Their are adjustments on the main video board of the projector for alignment of the three LCD screens, But these should only be made by a qualified professional as they can make it worse if done wrong.
Dec 07, 2007 | NEC MultiSync MT830 Multimedia Projector
Mt800 projector
First I would suggest cleaning the filter on the bottom of the unit where the fan inlet is. Over heating can cause many issues with the video controller in the projector, also shortens the life span of the bulb, always let the unit cool down when turning it off (let the fan run when you turn the power of by top button, never unplug and use the power switch on back. until the fan shuts off.)
Nov 24, 2007 | NEC MultiSync MT830 Multimedia Projector
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Sep 22, 2007 | NEC MultiSync MT830 Multimedia Projector
NEC MultiSync MT830 Multimedia Projector Logo
955 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
