Question about Intel Computers & Internet
Windows not loading and monitor not switching on
Actually when i switch on my computer...only green light lights up not the red one which shows its loading..... and after a while cpu goes off without switching on the monitor...........
and wen for the second time i switch the cpu on... a special kind of sound comes out from it....and again the same procedure continues.... "please help me"
    Problem Solver:
  • 9 Answers
Usualy the red light is the LED for the harddrive. Have you removed the hardrive and replaced it? Is there a reason that maby the power connector is not attached. Also, Is this computer a privately built pc or is a general manufacturer, like Hp, Dell Compaq etc. Also, If the battery on the motherboard has gone south then the bios setup setting will not be saved and the machine would not know how to boot. If the drives are all connected correctly, when you first boot the machine start tapping the del button. Depending on the Mfr, For some Hp's you need to tap the f1 key, there should be a message during the first part of the boot where it says, "To enter setup hit del, or F1 or etc." After you are in the blue screen of the bios, look for a message that says enter default settings. Hit that key, then F10 to save, exit, and boot. If this fixes the problem, then you will see the red LED for the hard drive illuminate and if the hard drive is intact with the OS then it should boot up. If it does boot up, after you are finished for the day, shut your system off as you usually would. The next time that you boot your system, if you have to enter the bios setup and enter the default setting again, then more than likely it is the motherboard battery. It is a bit difficult to diagnose something like this on the cuff. There are other conditions that can cause this like a damaged motherboard, bad memory, jumpers incorrectly set on the drives or motherboard just to mention a few. Hopefully this can be a place to start anyway.
Regards, Mike
Posted on Jan 19, 2009
  • Mike Hammond
    Mike Hammond Jan 19, 2009
    Follow-up.... from above.....Does you PC have onboard video or does it have a separate video card? Check and make sure these connections are good and tight. Not just on the back of the pc but on the back of the monitor also. What type of monitor are you using? If you have upgraded monitors from a CRT to a LCD then you will need to have enough video RAM to push that monitor or it will not display. I have found that even with the 15 to 17 inch low res LCD monitors that you need a minimum of 64 MB of Video RAM to drive that LCD monitor. The computer must get the video working before the rest of the machine can continue in the boot up sequence.
How do I get my computer to turn on it is saying no signal?
1st, it is the monitor that says, "No Signal." That being; is the actual computer turned on?
If it has a green / red power light and you can hear the hard drive and fan running inside the computer case, then check the cable that runs from the back of your monitor to the back of your computer's case.
It may be disconnected of just bad.
If you cannot hear any noise inside the computer case or there is no power light on, then check the electrical cord in back of the computer's case to the wall. If that is good, check to see if there is a light switch that turns that socket on and off.
Jun 02, 2015 | Computers & Internet
I switched my 23" hannspree monitor off using the on screen off switch, now when I switch it on the light at the bottom of the monitor shows green then turns amber and the monitor won't come on. This is a...
Normally, monitors will show green (or other color) when there is a video signal available.
Amber is fairly common to announce 'I'm here if you need me.'
Jan 12, 2015 | Hannspree Computers & Internet
My intel dot station pc shows blue light on at the bottom when switched on with green light on the top side . Now, the green light is not showing up with the result the windows not starting.
I cannot find a manual or service manual. If the computer is on normally a green light means everything is ok. I dont know why your computer would have a blue light. If you are networked as a station typically your ethernt card will blink green for ok and red for data collisions, do you have connectivity.
Sep 02, 2014 | Computers & Internet
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
When the monitor is switched on an orange light shows, no green light and screen says 'going to sleep'
your computer is not able to "see" the monitor. Try going into the BIOS settings when u first turn on the computer by pressing F1 or whatever key your computer uses to enter "SET UP". Then, select the F key that will "load default settings". Then, press F10 to "save and exit" and press enter to confirm. If that doesn't work, you either have a bad/incompatable monitor or a problem with connections or the video card or port.
Apr 28, 2010 | HP Pavilion F1523 15" LCD Monitor
Acer screen will not go away
Did you try downloading Windows XP?
Apr 07, 2010 | Acer Veriton 7600GT PC Desktop
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
Red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Aug 07, 2008 | Intel Motherboard
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Computers & Internet Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
