Question about Casio Watches
I got the wrong instruction manual on how to set the time right in a different model of watch
Illuminator world time 5052 stainless steel back water resistant 10BAR JAPAN MOV'T Y CASED IN THAILAND 212A309H
4 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: Need an instruction manual for my Casio Triple Sensor watch
Hi there!
This site is quite useful - http://www.theusermanualsite.com/
Just log in with your Email & postcode to get a PDF of the information it holds.
If this assists you, Please rate as Fixya! (It's free)
Posted on Jun 21, 2008
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
  • 102366 Answers
SOURCE: I have lost the instruction
Take a look at http://www.armitron.com/watch_instructions.asp
Posted on Nov 10, 2010
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
I had to change the battery, however, now I can't set the correct time. I need a print out!
Hi, If you don't have the manual, Try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Casio GShock Illuminator watch
Problem with WAVE CEPTOR watch band
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
May 06, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I own an Elgin man's wrist watch with quartz movement. It has the N, S, E, & W, on the cover together with" 30 NE 60, 120 SE 150, 210 SW 240 & 300 NW 330. It's water proof to 30 meters. Stainless...
I think it maybe the same watch that i had purchased years ago. I have an Elgin D275A Wrist Organizer Calender World Time Telememo Scheduler Ana-Digit and yes i do have the manual and i have a scanned copy of it i can send you. It's an impossible watch to find now. you can email me @ jdonohew@yahoo.com
Apr 01, 2010 | Bulova Watch
How do you move the time up 1 hour on a casio illuminator
There are so many aplications use of the manual will be manditory.
Hope this tip helps
R/
David
Mar 17, 2010 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
World time zones
It may be set to DST (daylight saving time), see instructions for changing this.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 07, 2010 | Casio Baby-G Wristwatch
Set time casio illuminator
Hope this tip helps.
R/
David
Dec 29, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Change annalog time Casio illuminator
R/
David
Dec 22, 2009 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
Watches Logo
14 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
