Question about GE DPSR483EA Electric Dryer
Belt Not Tight
I had a squeling noise in the dryer (GE DPSR475EWOWW)and I removed the drum as explained in the June 23 note between poorman1 & catriver. I found the noise by spinning the fan from its motor and it was dragging against the metal in front of it. I bent the metal out slightly and the noise went away. However, a new problem got me! I cannot seem to get the belt tight. It was tight when I removed the drum and I slid it off the back of the drum when I removed it. Now it is very loose and I have it around the drive shaft of the fan motor and a white pulley on a crome bar. This bar seems to activate a switch on the bottom of the dryer but I see nothing that will force this pulley out to keep tension. Any suggestions on how to get this belt on? Thanks in advance, MrTryToFixIt
  • Pieter Seidel Jul 05, 2007
    I bought a new belt assuming that I had streched out the original one and they are the same length. I cannot seem to find out how the tensioner arm maintains tension. Everything I read is that there is a spring or something but this GE profile just has a crome arm holding the pulley and what seems to be a switch that is depressed when the arm is pulled in towards the drum. Does anyone know how this tension system works?
The belt gets tight when you press the pulley arm down place the belt over the outer edge of the pulley and then over the motor axis. The belt then runs like in a "eight". Christian
Posted on May 25, 2010
  • 944 Answers
Best thing I can think of apart from contacting Catriver is a new belt - all this you describe sounds like it could have over-stretched - if you need help sourcing one please ask again (try Catriver first - he Knows) Hope this helps :)
Posted on Jun 26, 2007
My ge electric dryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Hi lorri jenkis
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them and is in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Oct 06, 2012 | GE DWXR483EBCC Electric Dryer
I have a G.E. dryer and it is making a loud rumbling noise when the clothes are dry or weighing less. Does that make sense? What could be the problem? Thanks.
Hi wendy8480...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
This is a FREE answer, Please take time to rate me
Aug 18, 2011 | GE DBL333EA Electric Dryer
Dryer making load noises and vibrates. still heating well but it is about 23 years old
Hi evella...
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Apr 20, 2011 | Maytag Dryers
I have a GE gas dryer and it runs but has recently started making a thumping noise. I can spin the drum by hand and it doesn't make the sound. What's wrong with my dryer?
Apr 11, 2011 | GE Dryers
Extreme squeling
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
of machine oil such as 3 in One oil.
Please rate me
Dec 11, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer makes interminent squeaking noise when drying.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Oct 04, 2010 | GE DBSR453EBWW Electric Dryer
My GE Dryer Model # dx4500ee1ww makes a load squeaking noise?
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Aug 10, 2010 | GE DBXR463EDWW Electric Dryer
Squeling on dryer model #dpsr475ewoww
replace the belt and tensioner pully to eliminate the squealing
Sears sell these parts in sets
Jun 07, 2010 | GE DPSR483EA Electric Dryer
Grinding noise in the dryer
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 27, 2009 | GE Dryers
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
GE DPSR483EA Electric Dryer Logo
292 people viewed this question
Top GE Dryers Experts
vince
gbob59
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
