Question about Cell Phones
You can't connect before register an available network for globe tattoo broadband
  • 196 Answers
SOURCE: Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Posted on Feb 16, 2006
tigereye143
SOURCE: im using globe broadband connection yet im unable to use ym
I got the same problem as yours.. (I think) that globe manages its connections from sites that uses lots of bandwidth(Yahoo messenger server for example). In doing so, making the Yahoo messenger server unreachable by their server. With this reason you can't use any messenger for yahoo that contacts the same server as yahoo have.
I solve the problem by installing a third party software called Trillian Astra. Its free and safe to use. Try it, hope that this will help.
Note: I myself don't advertise any softwares or sites. Just wanted to help, so if ever I violated any of the Terms and Conditions of this site. Please delete my post. Thank you
Posted on Jan 22, 2010
  • 62 Answers
SOURCE: how can i get my
Right click on Internet Explorer. Select Properties. click on connections tab >LAn Settings > Place a check mark on "Automatically detect settings". click on Apply, OK.
This should work.
Posted on Nov 29, 2010
  • 161 Answers
SOURCE: connect the wire of the
globebroadband preffer IPs..try to encode the IP provided by globe for you..
Posted on Jul 11, 2011
  • 223 Answers
SOURCE: How do I get my net book to use wifi? I usually
First of all you may want to decide to check out if the wifi connection is disabled or enabled.
If you go to system settings, in the network area you should be able to see if the wifi card is enabled. If is not enabled you may want to right click on the wifi icon connection and click on enable.
If this was the issue you know should be able to see and display all available networks in your area
Posted on Aug 03, 2011
I can't connect to internet, Im using globe tattoo broadband.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Jan 14, 2013 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Cani change my usb broadband stick which is globe tattoo into a sun broadband
Yup! You can change it there is no problem. You can also install them both in your laptop if you want. Because there signal is coming from different IP's
Sep 19, 2011 | Cell Phones
I have a CDR King Router L8186. I want to put a password
Hi
i had the opportunity to use both Smart Bro and Globe broadband internet with my CD-R King LP-8186 router. I had decided to document the configuration steps for both. For the most part, the steps indicated herein apply to both Smart Bro and Globe except otherwise mentioned in some areas. I had included the screenshots that would really matter and excluded the configuration that I left to their default values or settings. 1operation-mode.jpg?w=477&h=370
2wireless-basic-settings.jpg?w=477&h=370
3wireless-advanced-settings.jpg?w=477&h=370
4wireless-security-setup.jpg?w=477&h=370
5lan-interface-setup-smart1.jpg?w=477&h=370
Here's the LAN Interface Setup that applies to Globe. Please note that DHCP has been disabled because the modem that came with my Globe broadband subscription has DHCP enabled thus the need to disable the DHCP server of the LP-8186 router. Also, the default gateway of 192.168.1.1 is the IP address of my Globe broadband modem which is a Prolink Hurricane 5200 modem.
5lan-interface-setup-globe.jpg?w=477&h=370
The last part to be configured is the WAN setup. This screenshot applies to both Smart and Globe.
6wan-interface-setup.jpg?w=477&h=370
Lastly, if you are using Smart Bro, the RJ45 connector from the Smart Bro canopy antenna must be connected to the WAN port of the CD-R King LP-8186 rounter.
If you are using Globe, the Prolink Hurricane 5200 modem must be connected to one of your LAN ports (not to the WAN port) of the CD-R King LP-8186 router. With Globe, the CD-R King LP-8186 acts only as an access point and all computers connecting through it are actually using bridge networking.
Sep 05, 2011 | Computers & Internet
Papaano ko ma openline ang ang smart bro sa globe tatto
The webpage has the tabs OVERVIEW, SPECIFICATIONS, and RESOURCES.
You'll find all the available drivers under Resource
Best of luck!
May 28, 2011 | Sierra Wireless 598u Broadband Wireless...
Paano ako magkaroon ng connection sa internet?please ituru ninyo sa akin kasi first time ko...
kelangan mo magsubscribe sa isang ISP provider tulad ng pldt, bayantel, digitel, smart, globe, or kahit sky cable..or kung gusto mo ng instant internet, bili ka ng globe tattoo or smart broadband kit..
May 17, 2011 | Microsoft Computers & Internet
How can i get my globe tattoo broadband faster, and when i get the connection and open my internet explorer, it says it has to diagnose connection problem while am already connected and below appears that...
This should work.
Nov 29, 2010 | Computers & Internet
How to install globe broadband-prepaid to a laptop?
please specify what type of prepaid broadband, is this USB tattoo stick? or 3g / WIMAX broadband?
  • For tattoo, you simply plug in the USB tattoo stick to your computer and it will install automatically
  • For 3G / Wimax, you simply plug modem into ethernet port using LAN cable
Oct 19, 2010 | Computers & Internet
My globe tattoo sim card was block and if i open it it demanding to enter the puk code..what doi do
I think my globe tatoo was blocked. Cause it won;t send. I have load yesturday but it won't send. what should i do?
May 16, 2010 | Cycling
Cell Phones Logo
377 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
