Question about Creative Labs PlayWorks PS2000 Digital Computer Speakers
Noise like a crrrrr... eaven when the volume is at the lowest point
Hi, My speakers does a noise like craking... It's like when you have some noise when you turn up or down the volume from a speaker and you have dust over the button! You know that crrrr crrr ? lol But on those speakers you dont have anny button and this noise is not stoppind eaven if i bring the volume down with my remote control. The noise stay at the same volume eaven if i put the volum up or down. When i press mute i dont ear annything. At least... But it's not really practical... Can someone help me with this? Is it possible that it could be the wires? Thanks alot for your answer! NatLee :-)
    Genius:
  • 2,985 Answers
This is feed back from a component in the computer or one of the external devices. Try progressively unplugging all peripherals one by one. Came back if nothing reveals it self
Posted on Jun 26, 2007
Try and unplug the speaker system from the pc does the noise still carry on ???? if yes the sound amplifer in the speakers is at fault if the noise stops then the sound card in the PC is at fault
Posted on Jun 27, 2007
SOURCE:
I have a JBL Venue sub12.It pops and crackles at certain levels.Ive had it for 5-6 years, dont use it much. Ive turned the volume down on the speaker to the lowest setting and it still makes the noise
It is hard to diagnose without seeing it, but most likely you need a new amp. We have them in stock. http://reconingspeakers.com/product/jbl-sub-12-amplifier-assembly/
Nov 21, 2016 | JBL Audio Players & Recorders
Humming/Buzzing noise in my Marantz SR5600-even on lowest volume-
Check the main filter capacitor at its power supply section circuit. Electro help
Nov 19, 2014 | Marantz SR-5600 Receiver
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Speakers are popping
you may have a bad cord to your speaker or a bad rca cord ive had some what the same thing it turned out too be a bad groung on the rca cord
Nov 29, 2009 | Audio Players & Recorders
Harmon kardon hk695-01,13 - Intermittent "gargling" noise
the noise is sometimes caused by dust in the volume control.
i would suggest blowing the dust out around the volume control if there is a manual control on the unit. use a small can of compressed air.. buy it at local walmart or computer store.
Apr 28, 2009 | Harman Kardon HK695 Computer Speakers
Feedback noise in speakers and Woofer.
hi wfj1310,
that feedback comes from the distance between the mic and the speakers only. Low the record level from the mic and make the distance bigger.
it makes feedback with any speaker, not only with woofer :-/
complements
Oct 25, 2007 | Audio Players & Recorders
Noise when changing the volume and connecting speaker to anything.
firstly check the cable, some times it may in loose contact
otherwise any radiation equipment is located near by the amplifier,
sol. replace the location of the amp. and check cable loose contact
other wise
it is due to its amplifier IC problem, it is weak due to over load signal, or temperature of IC make leakage
sol.replace IC
Oct 24, 2007 | Logitech Z-5300 Computer Speakers
Creative Labs PlayWorks PS2000 Digital Computer Speakers Logo
435 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
