When power is supplied to my ilive IT88b bar it has a loud feedback sound. there is no way when powered that it does not make noise.
When plugged in to the power source there is a loud static sound
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
localwonder
  • 6784 Answers
SOURCE: power supply issues
hi there, i recommend replacing the entire board. once you have a short like this, the micro board itself will become useless. the thin micro circuitry has become separated within the layers, preventing a closed current transfer. its best to order a new canvas so to speak.
Posted on Mar 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Posted on Apr 10, 2009
  • 5603 Answers
SOURCE: Hi,I turned on my Marshall mg series 100 dfx and
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Posted on Sep 03, 2009
  • 11800 Answers
SOURCE: how do I fix bad static?
Yes,loud static usually comes from bad isolation of sound signal path so it's probably a frayed cable or a loose jack. Or if you're unlucky some parts inside have failed.
Posted on Oct 26, 2009
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
How do I connect my ilive sound bar to my tv
connect the red and white rca plugs to your audio out,then plug power into the bar,then go to settings on your tv and turn on external speakers
Jul 17, 2015 | Televison & Video
Why isnt my tv sound comming out of soundbar
What did you plug into on television. Make sure it is Audio Out could be wrongly connected to component out or Audio in. Have you plugged in and turned on the AC power pack as this could be another possible cause of problems as the sound bar requires power. You may have a faulty AC power pack or power point.
I looked it up on Ilive's web site
32 Bluetooth Sound BarITB183B Press the power button first before selecting Source.Use the Source button on the control unit to switch between optical , aux inputs, line in. If you plugged it into the AUX in on the back you need to select Aux inputs (indicated by a white light) on the speaker. Do you have the user manual if not it is at http://www.iliveelectronics.com/fileuploader/download/download/?d=0&file=custom/upload/File-1380574738.pdf
Hope this helps as I do not have one myself
Jun 13, 2014 | iLive It202b 32" 2.1-channel Soundbar -...
Ilive sound bar
something(component) inside is moved out of place open it up find it and solder it or your input cable isnt the right onetry jiggling it or get a new cable
Jun 02, 2014 | Cell Phones
How do I set the clock on the ilive sound bar
With the power off push the clock button on the remote.
Jan 09, 2012 | iLive Itp180b Ipod(r)/iphone(r) Speaker...
My ilive won't turn on
1.Check first if there is a electric power on your location
2.Please try another device and plugged this device of where you plugged in first the I+Live sound bar.If the device you plugged in turn on it means that I-live has an issue on its power system.I would suggest to call the manufacturer or contact the store where you purchased the item.
Sep 04, 2011 | Audio Players & Recorders
My apple ilive wont turn on from the power even when its plugged in I have had the stereo for about 4 to 5 years what do I do
Hello mkdogg101
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
1. It appears that the system is out of warranty, lets try a few things to start off with
2. Check the power cord for obvious damage, ie. dog bite marks, damage to either side of the plug from wear and tear
3. Try to plug your system into a completely different outlet, preferrably one that you know for a fact works, ie. A lamp comes on etc.
4. Check all buttons on your system and attempt to power it on
5. If your still having problems with no power, please return for fast expert solutions.
Jan 10, 2011 | Apple iLive IBCD3816DT Portable 2.1...
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Powered sub
thats sounds like feedback. try giving your sattelites spacings. if they are near to each other, try to put them far from each other.
try also to turn of your microphone. that might work.
Jan 14, 2008 | Altec Lansing VS3251 Speaker
Televison & Video Logo
Top Televison & Video Experts
