Question about Sony V SERIES BRAVIA KLV32V300 32 in. LCD TV
Connect a tatasky to sony bravia tv
I HAVE RECENTLY BOUGHT A SONY BRAVIA 32S400A FOR WHICH I WANT TO CONNECT EXISTING TATASKY SET TOP BOX THE PROBLEM IS if you connect in the video input jack COULD NOT RECIEVE THE TWIN PICTURE [as i have ordinary cable] when i connect on HDDVD JACK i recieve tata sky in black&white pls EMAIL ME AND OBLIGE
SOURCE: Sony Bravia with Phillps dvd player
It's not compatible with the Phillips DVD player. We had the same problem with our old DVD player, something about reading it.
Posted on Oct 19, 2008
  • 87 Answers
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Posted on Apr 20, 2009
SOURCE: Regarding PIP (Picture in picture) facility
Sorry to say, you may not be able to do this. This will require you to have multiplexed inputs going into the TV. The out from the Tatasky set top will give out only one channel at a time.
Posted on Jul 15, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
gopakumarg43
  • 74666 Answers
SOURCE: I have connected cable (in India Tata Sky) to my
Hello
Bravia KDL series are for use in US and its reception system is differnt to that of in India. Your TV can only accept signals of NTSC and ATSC. These are the statds of transmission used in US. In India, all transmisssion and recordigs standards ar of PAL. Your TV won't accept PAL system signals properly. Theese systems mentioned above anr the colour transmitting standards. You have to choose a multisystem compatable TV from there in US. There is no hopt for you to get PAL type transmission signals to recive with your tV. It can play NTSC recoreded dvds or Blu-rays or Video casette tapws, whatever it may be, properly. There is no chance to get it converted to a multisystem, or even for a PAL system converstion with your TV. The colour informatin will not be processed properly. OK.
Posted on Feb 06, 2011
What is the part or serial number of sony Bravia KLV-32s400A?
Contact the nearest authorized service center for Sony at your town. The parts numbers to Sony might vary time to time. Only service center engineers can provide the correct number of part number used.
Jan 28, 2013 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
How to connect sony home theatre with sansui lcd connection with tatasky hd.
It is better to go through the operation manuals and follow guidelines step by step.
Aug 17, 2012 | Sansui HDLCD3210 32 in. LCD TV
How to fix out of range problem on sony bravia with pc
Well I just changed the resolution settings in my android box to 720 from 1080p > plugged it in and my box now works...simples.
Jan 29, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony Bravia Klv-32s400a Im looking for this parts Parts No A1527471G I do have this part on sale.
Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes Sony LCD tvs PCB boards.These two websites have very extensive Sony LCD tvs PCB boards.
Apr 16, 2011 | Sony KLV32S400A 32 in. LCD TV
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Jun 21, 2009 | Sony Televison & Video
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Sony V SERIES BRAVIA KLV32V300 32 in. LCD TV Logo
379 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
