Question about Car Audio & Video
Ignition i replace ciol plugs wires and i still got the #2 cly not fireing but engine runs my ciol melted on #2 plug wire the old one
  • 11,896 Answers
The module that the coil pack is connected to is shot if you don't have spark in that cylinder. If you have spark in that cylinder and it is still not fireing than you may have a bad injector
Posted on Jan 19, 2009
Shaking!
Sounds like a cylinder misfire. Did any of the sparkplugs have water on them? If so, you may have a bad head gasget or cracked head. If they looked ok, a valve may be stuck open or push rod bent. Locate the missing cly by pulling the spark plug wire one at a time while the engine is running. Use insulated spark plug wire pliers. If the engine slows down, cyl is ok. If there is no change in rpm. cly bad. Do a compression check to see if ok.
If you have a inferred thermo thermometer, check the exhaust manifold as it comes out of the head by the plugs. If a cyl is colder than another by a couple hundred degrees, it is not firing.
May 01, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
Need wire diagram for 99 durango firing order
Before carrying out extensive tests to isolate poor running problems, check connections of spark plug wires. This is especially important if plugs, wires, distributor, etc., have been disturbed recently for service. Obviously, this is not applicable to the wireless 4.7L engine.
NOTE To avoid problems, remove and tag the spark plug wires one at a time to ease reinstallation.
For vehicles with an extensive service history, keep in mind that the distributor could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason, it is very important that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired.
Fig. 2.5L Engine Firing Order: 1-3-4-2 Distributor Rotation: Clockwise
Fig. 3.9L Engine Firing Order: 1-6-5-4-3-2 Distributor Rotation: Clockwise
Fig. 5.2L and 5.9L Engines Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Fig. 4.7L Engine Firing Order: 1-8-4-3-6-5-7-2 Distributorless Ignition
Fig. 8.0L Engine Firing Order: 1-10-9-4-3-6-5-8-7-2- Distributorless Ignition
icn_arrow.gifBack to Top
Dec 30, 2010 | Dodge Durango Cars & Trucks
Changed plugs and wires on a 94 ford explorer and now it 's not tunning right. need a diagram. please.
FIRING ORDERS NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. Fig. 1: 1991-94 2.9L and 3.0L Engines Firing order: 1-4-2-5-3-6 Distributor rotation: Clockwise 85552008.gif
Fig. 2: 2.3L, 2.5L Engines Firing order: 1-3-4-2 Distributorless ignition 85552010.gif
Fig. 3: 1995-99 3.0L Engines Firing order: 1-4-2-5-3-6 Distributorless ignition 89682g23.gif
Fig. 4: 4.0L Engines Firing order: 1-4-2-5-3-6 Distributorless ignition 85552009.gif
Fig. 5: 1996-99 5.0L Engines Firing order: 1-3-7-2-6-5-4-8 Distributorless ignition 89682g24.gif
Dec 09, 2010 | Ford Explorer Cars & Trucks
1999 volkswagon jetta vr6 check engine light on scanner says random miss fire on number 1 cly. and others. i changed plug wires and spark plugs no change. previous owner changed ciol pack i put old one...
The system's wiring needs to be checked for power. It could be that the driver for the systems injectors or coils may have an issue. What makes this a big problem is that the driver's are contained in the engine's ECU which is the main brain for the engine. Would you like a authentic shop manual for your library? Let me know.
Aug 18, 2010 | 1999 Volkswagen Jetta
Firing order diagram
Here is the firing order diagram for that vehicle, and if the ignition wires are not crossed then one of the spark plugs might have been damaged while installing it and the spark plug gap closed on one of the spark plugs, or one of the ignition wires (spark plug wires) has been damaged, and if those wires are over 5 years old then you should replace them. I hope that this helps you to solve your problem.
Jun 05, 2010 | 2000 Ford Windstar
Cyl. 3 miss fire code po303
my money would be on the coil cover, especially if it had been a long time since the last tune up. it is certainly worth trying, as this is part of a routine tune up anyways. good luck!
Mar 18, 2010 | 1999 Pontiac Sunfire
Number 2 spark plug
Are you sure it's the spark plug that's faulty or the ignition wire?? How old are plugs and wires?
If you don't know if it's your spark plug not firing or your ignition wire you could move spark plug to number 1 then check your code reader.
Or you could do an ohms continuity test on your number 2 ignition wire to verify that there is no break in the wire. Common problem to check for. If wires and plugs are old and high mileage maybe should change all including cap and rotor on distributor. Fresh wires plugs cap and rotor always improve mileage and performance.
Good luck, sorry can't help with tranny.
Dec 10, 2009 | 1998 GMC Jimmy
Need firing order and, I need to know what side the number one piston is on?
The 3.5L (VIN H) engine's unique ignition system has the ignition coils directly over each plug. No spark plug wires are used.
If a coil is replaced on any of the 3.1L, 3.4L or 3.8L engines, it may not be numbered, as is the factory coil. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your guide to reflect how your engine is wired.
Fig. 3.1L (VIN M) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.4L (VIN X) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.4L (VIN E) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.5L (VIN H) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.8L (VIN 1) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
Fig. 3.8L (VIN K) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
The firing order for the 3.1L VIN M, 3.4L VIN E, 3.4L VIN X and 3.5L VIN H engines is 1-2-3-4-5-6. The right bank cylinders are on the cowl side (rear) of the engine compartment and are numbered 1,3,5, left bank cylinders on the front side of the vehicle, are numbered 2,4,6.
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6
Hope helped (remember rated this help) Good luck.
Oct 19, 2009 | Pontiac Grand Prix Cars & Trucks
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
