Question about iRiver B30 (8 GB) Digital Media Player
II have Windows 7 & IRiver B30 and IRiver 4 don't want to work together, IRiver4 freezes just about everytime i connect the mp3
IRiver B30 worked well with Windows XP and IRiver 3 software, but I have real problems with IRiver4 which I need to run with Windows 7. Is there a patch?
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Posted on Jan 25, 2008
SOURCE: iriver mp3 player
One more solution, if the ones above do not work for you: (1) Open the x20 (internal drive: click) in Windows Explorer, (2) Save all of your music into folders (playlists) create in MyMusic (under MyDocuments), (3) highlight all of the folders you created (use the control key), (4) drag all of the folders onto the x20 into the internal drive of x20, (5) Find and play the folders under 'Browse" on the x20.
You have playlists. You just have to 'Browse' the x20 to find them--not 'Playlists'.
Posted on Apr 26, 2008
SOURCE: mp3 player iriver t10 hard reset
ive got the extact problem hs anyone found a fix for this ?
Posted on May 01, 2008
SOURCE: Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Posted on Sep 20, 2009
SOURCE: I cannot download from my ifp-700 iriver player to windows vista
I cannot install my i rivewr 700 to may new computer with windows 7.Is there a problem with w7? can I download a driver for this?/J
Posted on Sep 11, 2010
I have an ifp 790 iriver player. I have Windows 7. Iriver music manager does not work on Windows 7. I tried the compatability factor on Windows 7 and it does not work. Please help me! I need to be able to...
What type of Windows 7 do you have? Is it 32-bit or 64-bit? If you have 32-bit, then iRiver Music Manager should work. However, if you have 64-bit, it will not work, according to a phone call I made to iRiver several months ago. I had the same problem as you, and so I called iRiver and that is what they told me, and then I exchanged my 64-bit computer for a 32-bit computer and now the iRiver Music Manager works.
Sep 25, 2011 | iRiver iFP-790 MP3 Player
Win 7 64 bit freeze when starting XiMeta's NDAS NetDisk. I'm using newest version 3.72 from Ximeta website.
I have the same problem. I don't have the right solution but I discovered a workaround.
The problem occurs everytime when I install a windows 7 update.
My work around:
  1. When Windows determines an update I disable the NDAS service with msconfig
  2. The update is installed without the NDAS service operational.
  3. After update I enable the NDAS service with msconfig
  4. I restart my computer. Then it freezes.
  5. After a hard reset, the computer restarts in Safe modus. I restart my computer and my computer works, till the next windows 7 update. Then I start again van 1.
Very suboptimal, but it works.
Anton
Jul 08, 2011 | Ximeta (NDU10200CU)
I recently found a black iRiver H10 but don't know how to sync music. I bough an USB cord for it but now what?
Hi maria lopez0...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
Jun 27, 2011 | iRiver H10 MP3 Player
I record movies on windows 7 media centre and can't play them on my iriver e100 player. I also can't watch mp4 format. What do I need?
Greetings - your IRiver E100 only plays certain .avi files and versions of Windows Media (.wmv) files.
To use your media center and MP4 files you would have to obtain converter software that would convert the files to be compatible with your player. Recording TV shows creates files which are incompatible with the E100 as are MP4 files.
For the TV recordings you would have to do as follows:
Forget the mention of IOS device above - you need to do the same step.
You then have to convert them to files that the player can use. I'm told this software works well and is only $9.95 (USD). Take a look HERE. (I have no connection with this company).
For other files (like MP4 files) you just have to use the converter software I mentioned above and don't need the first step I displayed above.
Enjoy your Video.
Mikeywaf
May 14, 2011 | iRiver E100 Digital Media Player
A friend gave her iriver mp3 player to my sister and won't connect to the computer saying that the driver is not installed but she's downloaded it twice. why won't it work?
try this uninstall the old one and download this
  • http://local.iriver.com/usa/lounge/loungeView.asp?selectPart=01&findWord=&sno=723&page=1&cateCode=01
after you have downloaded go to my computer / connect the iriver you shoud see another drive appear..and if this is windows xp it really should come up automatic...
Jun 17, 2010 | iRiver T30 MP3 Player
I have an Iriver T30 and I have lost my manual?
A manual for the T30 can be acquired going to next link:
http://www.iriverinc.com/lounge/loungeList.asp
In the bar "select a product" select your player and click GO on the right side. All support for this player will be viewed.
T30 English manual link will show up in the list. On the next page you can download the zip file for either iRiver Plus2 or Windows Media Player.
Not sure if the T30 will work with Windows 7.
It depends on the firmware you have in the player.
Normally Windows Media Player should detect the T30 in MTP mode.
When having firmware that only detects the player in MSC mode, seeing the player as a removable disk: there are MSC drivers available under software&driver ( T30umd.inf ), not sure if they'll work on Windows 7.
Feb 23, 2010 | iRiver T30 MP3 Player
Iriver, H10 , system files missing
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Sep 16, 2008 | iRiver H10 MP3 Player
Freezes
Reset by removing and reinserting batteries
-Tha Mp3 Doctor
Sep 03, 2008 | iRiver H10 MP3 Player
IRiver H10
I can not do anything with my iRiver as it only says "System Files Missing" and "Connect to iRiver plus II" which I have done but nothing happens. I do not want to loose the songs on my iRiver.
Dec 17, 2007 | iRiver H10 MP3 Player
iRiver B30 (8 GB) Digital Media Player Logo
62 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
