The game eant run
SOURCE: I have a proscan PLT7223g tablet and trying to
You can avoid these errors if you have a stable internet connection. If the internet disconnects in the middle of the download then the error might occur. You can also try going to settings, applications and locate the google play store and tap it . On the play store tap clear cache. One of the reasons that the error occurs is if the download manager was moved to the sd card. Make sure also to check that. You can unmount the SD card and try.
SOURCE: put my apps on my sd card
Go to applications section under settings and click on the one you want and it should open up and there is a button transfer to sd card.
if it was a built in app it can not be removed so have a good look about in apps. there are also other camera apps that can be used which are free and you can get them from google play store.
SOURCE: How do I know what apps can be removed safely?
most app can be removed safely by holding your finger on the icon and when it starts ti flash then click the delete button
delete all apps that are not every day users ( and most will not be )
