Question about GE PSC23NGN Side by Side Refrigerator
Set temperature ge profile psc23ngn - GE PSC23NGN Side by Side Refrigerator
  • 358 Answers
SOURCE: No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Posted on Oct 01, 2009
SOURCE: GE profile refrigerator digital temperature settings keep
my ge profile temperatures keep changing
Posted on Jul 01, 2010
  • 1891 Answers
SOURCE: GE Profile Artica 22.6 cubic feet side by side
may need a main board or sensors that control the board . or both . ,, mm
Posted on Aug 11, 2010
  • 2699 Answers
SOURCE: my ge profile refrigerator won't keep it's
G.E. has had problems with the main computer board located on the back outside wall of the machine,you need to give the parts store or whoever you get the board from the full model number to get the correct board.i looked up the machine with the number you sent but there are 2 different boards that they show so open the fridge door,look up near the ceiling on the right hand wall and you'll see the model and serial number,all you need is the full model number or you can send it to me and i can look it up for you.good luck
Posted on Jan 13, 2011
  • 91 Answers
SOURCE: How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Posted on Jul 03, 2012
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My ge fridge will not keep a constant temperature. the fridge is 24 degrees and the freezer is around 6 degrees.
    Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
    Refrigeratoris Too Cold and Freezing Food
    heatman101
    Jul 16, 2011 | GE PSC23NGN Side by Side Refrigerator
    FREZER NOT GOING TO DEFROST
    Have you already press the defrost setting or turn the defrost knob? If you do and still not on defrost. then replace the defrost with similar type and size if you can. If you cannot, call a service technican to do the job.
    Thanks for asking.
    Jun 23, 2011 | GE PSC23NGN Side by Side Refrigerator
    GE Profile Side-by-Side Refrigerator gets to too cold
    turn the temp setting up to40 then check in a couple of hrs
    Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Buttons on Control Panel not working for my GE Profile Gas Range
    Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
    Thanks
    Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
    GE PSC23NGN Side by Side Refrigerator Logo
    79 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
