Question about Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer - White
My Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer will not agitate or spin clothes out. Please HELP!
It had a problem draining before but I fixed it by cleaning the water pump hose.It worked for 3 days then it left clothes soaked. I ran it without anything inside today to see if it would work, now it will neither spin nor agitate.
    Sergeant:
  • 291 Answers
You should check your serial number at this link:http://www.cpsc.gov/cpscpub/prerel/prhtml09/09292.html
There was a voluntary recall issued on your model number. The serial number will confirm if your machine is affected.
As to your problem, i would still suspect drain pump is struggling or inoperable. However if it seems to drain ok and your pump is still relatively quiet except for a nice mellow steady hum (there should be no rattling sound) then i'd take a look at the pressure switch. The pressure switch sends the signal to begin agitation (water level in tub is full) and spin (water in tub is drained.)
Posted on Jan 03, 2013
Macmarkus
  • 2605 Answers
SOURCE: Frigidaire affinity front load. Starts
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Dec 12, 2010
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
onthejob5130
  • 640 Answers
SOURCE: Frigidaire GLTF2940ES Front Load Washer
you have a defective motor control board
Posted on Jan 08, 2009
blueextc3221
  • 15935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Oct 01, 2010
SOURCE: washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Posted on Nov 14, 2008
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Washing machine will agitate but won't spin out water
Good Morning Friend,
I understand that your Frigidaire washer, model# ATF6000ES, is agitating but not spinning the water out of your clothes. I suggest trying the following solutions:
    1) Make sure you select the appropriate spin speed for the load.
    2) Make sure you do not overload washer.
    3) Make sure the load is not too small. Add 1 or 2 similar items to help balance the load.
    4) Make sure the load is not out of balance. Rearrange load to allow proper spinning.
    5) Make sure that the drain hose is not kinked. Straighten drain hose.
    After checking the above, reset your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Dec 04, 2012 | Speed Queen SWFT71 27" Coin Operated...
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Just bought brand new commercial coin operated washing machine top load...everything is level tried washing a load and at the spin cycle the machine vibrates so bad it seems like it's going to take off. ...
maybe when you were moving it, one or more of the springs that keep the drum centered came off,unhook everything,drain it,tip it over face down on a piece of clean carpet, make sure everything is in order,all supports are in place, 2 people to tip it
Jan 31, 2010 | Whirlpool CAM2752RQ Coin Operated...
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Basket spins while agitating
transmission defective...not a special problem,,,the transmission shot...
Jan 05, 2009 | Whirlpool GSC9455 Top Load Washer
Washer won't spin
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Oct 26, 2008 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer - White Logo
364 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
