Question about LG F-185 CD Shelf System
Replace TDA 8566
I need to replace TDA 8566TH by another equipvalent IC.Thanks.
Samsung crt tv ic tda 9381 mute system not working &No audio . audio ic tda 7297sa
IC fault. Replace the TDA9381. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 29, 2016 | Samsung Televison & Video
TDA 11105VS/ P3 servicemode
If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 31, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Tda 9370
Check the video output RGB out terminals of the TDA9370. Check the voltages. If can, check signal waveform. You have't specified nothing about the audio status. If you wish to get the schematic of TVs, using TDA9370, check the site linked here. Never confirm that the IC is OK. Check the serial data & serial clock. Replace the main system control memory IC, too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 21, 2013 | Televison & Video
Blinking red light
You did not give a model number. If this is an older model Sony, I would be concerned with the audio IC with standby. This IC will be of the TDA-XXXX series. I doubt if you have a problem with power supply. If you can locate the IC mentioned, and read the TDA number, cross reference this in an NTE semi conductor manual. If it does tell you it is an audio IC with standby...replace this IC with the cross reference. Be sure to check any grounds that need resoldered in the same area as the IC mentioned. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sony Televison & Video
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
TDA 8364
Look it up at nteinc.net
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
LG F-185 CD Shelf System Logo
146 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
