Question about iLO (2 GB) MP3 Player
Computer locks up everytime I connect my USB cable into the MP3 ilo 2GB player.
Just bought the new WalMart MP3 player called the ilo 2GB. I used the stat-up disk but Media Player won't load correctly and every time I plug in the player the mouse on my computer locks up andI have to unplug my system to get it to shut down. What's wrong and how can I fix this issue?
  • 432 Answers
Take it back to WalMart and get another one. This is broken.
Posted on Jun 26, 2007
SOURCE:
Cannot download
Make sure the lock/hold is not engaged
"Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
Download the correct Firmware
Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware
Click Open to initiate the download
Double click on the ILO or Siren folder icon. There will be 14 icons.
There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
Then click Run - this will open the Install Wizard.
The Install Wizard has the instructions on the screen as you go through it.
Once the firmware has installed, please click the Start menu, then Programs.
Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
-Tha Mp3 Doctor
Sep 25, 2008 | iLO (2 GB) MP3 Player
Need manual and disk
No longer carried or supported by manufacturer - out of luck
Jul 12, 2008 | iLO MP3 Player
Wont turn on
Walmart is still selling an iLO brand player that has an SD slot.
http://www.walmart.com/catalog/product.do?product_id=4127960#Specifications
May 01, 2008 | iLO (2 GB) MP3 Player
Ilo 2gb mp3 player
the computer has not have the right thing to play your iLO. I would look at the owners manuler and see what your computer needs or inserted the iLO CD
Mar 30, 2008 | iLO (2 GB) MP3 Player
ILO 2GB MP3 Player Not Working!!!!
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 12, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player
what is the model and brand of the mp3 player?
if when you plug the device to the pc, the device ask you for a mode, you could try some option called transfer mode.. that way the pc could detect the device as some sort of pendrive...
Mar 11, 2008 | Audio Players & Recorders
Ilo MP3 player locks up when plugged into MAC or PC
2)
Mar 05, 2008 | iLO (2 GB) MP3 Player
ILO mp3 player stopped working
2)
Jan 12, 2008 | iLO (2 GB) MP3 Player
Ilo MP3 player
someone said walmart but walmart tells me that is not true
Jan 07, 2008 | iLO (2 GB) MP3 Player
Ilo 2gb mp3 flash player cd problems
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 26, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
75 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
