Factorial 1.definition 2.sample algrithm 3.sample program (simple c comp)
  • jaypee_manin Jan 22, 2009
    thanks
  • abhinav07
    abhinav07 May 11, 2010
    hello sir,
    sory 2 say bt i donot understand ur prob . be brief
    Abhinav
  • 3 Answers
1.In mathematics, the factorial of a non negitive integer n, denoted by n!, is the product of all positive integers less than or equal to n. For example,
factorial - c018852104089c3b86ad5bba9e9223f9.png and2. Algorithm to find factorial of 6
1. Start
2. Take two variables i and j.
3. Take a constent VALUE=6.
4. Put i=1,j=1.
5. If i is less than VALUE goto 6 else goto 7
6. j=j*i and goto step 5
7. Print j value.
8. Stop.
/* Program to find factorial of 6 */
#include <stdio.h>
#define VALUE 6
int i,j;
void main()
j=1;
for (i=1; i<=VALUE; i++)
j=j*i;
printf("The factorial of %d is %d\n",VALUE,j);
Posted on Jan 21, 2009
I have DCA analyzer from Siemens healthcare and i have problem E24 ,How Can Solve it
Manual is available in PDF format from here
http://docslide.us/download/link/dca-operators-guide
http://docslide.us/download/document/?id=%2FJKJQj2KkZIjS9Tn4Jm5CAbRibVv%2BGl%2BT9wi7I03ZyGSjZf8c1bXQnPy2%2FSc3BFIu8t3mvccp4VXj23OQyX8pQ%3D%3D
DCA Vantage Operator's Guide 109
Troubleshooting
E22 - Optical
reading is out
of range
A Sample or Reference
channel reading taken
during an Air
measurement is too
high.
1. Discard the sample.
2. Run an optical test.
3. If you are unable to run an
optical test, contact your local
technical support provider.
E23 -
Excessive
noise on the
Sample
channel
The standard deviation
of the 16 readings at the
Sample channel for Dark
or Air reading is too
large.
E24 -
Excessive
noise on the
Reference
channel
Reference channel for
Dark, Air or Sample
reading is too large.
E26 -
Excessive
noise in sample
reading
Sample channel during a
reading taken is too
large in Sample read
position.
E27 -
Excessive
Lamp Drift
The change in mean
signal between
successive Air readings
is too large at either the
Sample channel or the
Reference channel.
E30 - Thermal
control system
error - low
The temperature
measured by one of the
cartridge holder
thermistors is ?2?C.
2. Restart the system.
3. If you are unable to perform a
successful restart, contact
your local technical support
provider.
E
Sep 21, 2015 | Siemens Dishwashers
Tip
How to convert MTS and M2TS files to QuickTime for editing in iMovie Trace back...
Trace back to iMovie'08, Apple has announced that this bundled video editing software works with many tapeless camcorders that record to HDD, flash memory, or DVD media, including camcorders using MPEG-2 (standard definition) and AVCHD (high definition) formats. With the release of iMovie'09, it expands supported camcorder formats from MPEG-2 (standard definition), AVCHD (high definition) to MPEG-4 and H.264 formats. However, it does not mean that iMovie will be an all-pass application to any sort of camcorders and cameras. Due to the wide range of media types and the different ways manufacturers store videos on these media types, Apple has reminded users that not all tapeless camcorders are compatible with iMovie'08 and iMovie'09. AVCHD camcorders which capture footages in the format of .mts/m2ts are among this range to some extent.
To make it possible for Mac users to edit MTS/M2TS files shot by AVCHD cameras in iMovie, this guide will provide a solution to the problem of how to convert MTS/M2TS files to QuickTime on Mac for editing in iMovie.
What you will need is Pavtube MTS/M2TS Converter for Mac. Read on the following contents to find out a step-by-step instruction.
Step 1: Click "Add" button to import MTS/M2TS files to this program
Step 2: Select QuickTime (*.mov) as output format for iMovie
Click on the drop-down list of "Format", and follow "Common Video" > "MOV-QuickTime (*.mov)".
Step 3: Set advanced settings
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the following window.
By the way, if you’d like to combine all the added files to be as a single file, you can tick the checkbox "Merge into one file" to realize it. Also, if you do not want to use the default save path, you can click "Browse" button to look for and specify a destination folder.
Step 4: Convert
After the above steps are done, you can click "Convert" button to start conversion. And you can click "Open" button to get the generated QuickTime .mov files effortlessly. Afterwards, just import the output files to iMovie for editing. Click here to see How to edit videos in iMovie.
Additional Tips:
1. The program adopts advanced audio and video sync technology, and never lets your video and audio go in separate way.
2. This program optimizes its conversion speed with multi-thread technology, so that you can convert MTS/M2TS AVCHD files 1.5 or 2 times faster than other similar programs.
3. Its trim and crop functions allow you to select the proper time length for MTS/M2TS videos, as well as cut off any unwanted areas.
4. It Provides users with simple gauss blur effect, which is very useful to recorded files, since it can eliminate the noise of recorded videos. If you like, you can also add other special effects including simple laplacian sharpen, gray, flip color, invert, aged film, etc. to your video files.
5. It allows users to add various watermarks, such as text watermark, image watermark, GIF animation watermark and video watermark.
on Apr 08, 2010 | Computers & Internet
Codes P2270& P2272 after oil change check engine light on drove under 100 miles both O2 sensors bad .Could shop have caused this somehow??? Maybe banging them or something ?
make sure they are plugged in tight Definition of Diagnostic Trouble Code P2270 Category: Powertrain Definition: O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 2Note: This definition of P2270 is applied to all manufacturers
P2270 - O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 2 Comments ' Add Yours
Possible causes
- Faulty Rear Heated Oxygen Sensor Bank 1
- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Exhaust gas leaks Help with this
When is the code detected?
The Powertrain Control Module (PCM) detected the HO2S12 sensor has reported a lean condition for an extended period during an intrusive test
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- High Fuel Consumption
- Excessive Smoke from Exhaust
P2270 Description
The Powertrain Control Module (PCM) supplies a voltage of about 450 mV between the HO2S high and low signal circuits. The oxygen sensor varies the voltage over a range from about 1,000 mV when the exhaust is rich, down through about 10 mV when the exhaust is lean.
The PCM monitors and stores the heated oxygen sensor (HO2S) voltage information. The PCMevaluates the HO2S voltage samples in order to determine the amount of time the HO2S voltage was out of range. The PCM compares the stored HO2S voltage samples taken within each sample period and determines if majority of the samples are out of the operating range.
Definition of Diagnostic Trouble Code P2272 Category: Powertrain Definition: O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 2Note: This definition of P2272 is applied to all manufacturers
P2272 - O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor 2
' Add Comment
Possible causes
- Faulty Rear Heated Oxygen Sensor Bank 2
- Rear Heated Oxygen Sensor Bank 2 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 2 circuit poor electrical connection
- Exhaust gas leaks
What does this mean?
The Powertrain Control Module (PCM) detected the HO2S22 sensor has reported a lean condition for an extended period during an intrusive test
Possible symptoms
P2272 Description
P2272 Information for specific makes
P2272 BMW
P2272 DODGE
P2272 FORD
Jul 30, 2015 | Cars & Trucks
How can i drill a hole into my keepsafe wall safe to open it?
Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
What are the steps in solving for probability on C?
If you have nine marbles in a bag, four of which are blue, then the probability of reaching in and pulling out a blue marble is four out of nine, or 4 divided by 9.
Stay in the normal computational mode and press 4 / 9 =
If you want to know the probability of pulling out three (for example) marbles and getting at least one blue marble, then you get into combinatorics. The answer depends on whether or not you replace each marble after pulling it out (Sampling with/without replacement).
Probability is a rich and varied field of mathematics. People have spent lifetimes studying it.
Nov 06, 2011 | Casio FX-115ES Scientific Calculator
How to form an array in visual basics(Express)
samples of arrays in vb.net
1)
dim array(3) as integer
array(0)=1
array(1)=2
array(2)=3
array(3)=4
2) dim array() as integer
array=new integer(){1,2,3,4}
3) for two dimensional arrays add comma separation to the size
May 28, 2010 | Microsoft Visual Basic Enterprise Edition...
Audio
if audio is not working// follow all this steps:-
1)check for mute button// it should be on//
2)control pannel/sound icon double click// check default speakers/ test the sound
3)uninstall the sound driver from device manager by clicking on the plus sign and right clicking on the poped driver/ restart the computer/ check by playing the sample music it should work//
how to go to device manager?
xp comp; right click on computer/properties/hardware/device manager tab
vista comp:- type device in start search at the bottom after u click on start button. device manager will be populated on top click on that and the window will open.
May 07, 2010 | Compaq Presario 700 470024-192 Notebook
How we can capture a tcp packet using java program
Hi!
1. If you want to write a packet sniffer in java, please review this
useful links:
http://www.rohitab.com/discuss/lofiversion/index.php/t28724.html
jpcap:
http://netresearch.ics.uci.edu/kfujii/jpcap/doc/samples.html
I suggest to use the jpcap library it developed for packet capturing and it contains sample code too.
2. If you want to search for a simple exe program which captures
the ethenet packets wireshark is a good solution:
www.wireshark.org
Jan 06, 2009 | Computers & Internet
MY lock 204D tension problem.
Check all the tension units are clean and clear of lint
Ensure sharp new needle/s,
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, and that you have threaded through all the guides.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
Now set up machine with 4 different colours, so you can easily see any changes you make.
Factory setting for all 4 tensions = 3.........try this setting first before altering anything.
Sew a test sample about 75mm (3") and look at the result, front and rear.
You will see anything tight or loose, so just adjust a little at a time with test samples each time.
If the actual knobs read anything other than the 3-3-3-3, after you have made your adjustments and are happy with the balance of tensions, it is quite simple to remove the knob....very gently pull it off towards you (without altering the new found correct tension !!) and pop it back on to read 3.
Hope this is all easy to follow, If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
May 09, 2008 | Janome Memory Craft 10000
Audio settings
default values of the secret E370 audio menu by inputing *#8999*8378*
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
Rx vol - Lv 8 - 1560
Rx vol - Lv 9 - 2167
Rx vol - Lv 10 - 2863
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Rx vol - Lv 7 - 1148
Rx vol - Lv 8 - 1312
Rx vol - Lv 9 - 1476
Rx vol - Lv 10 - 1640
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Oct 04, 2007 | Samsung SGH-E370 Cellular Phone
Computers & Internet Logo
204 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
