Washing machine faulting, not filling
F&P Gentle Annie GW52 fills for 3 secs, stop for 3 secs, does this 3 times then stops altogether with an alarm (same as the finished cylcle noise) with one light on the panel lit - the Spray rinse light. Wont continue on through rest of fill and therefore the wash cycle. Tried a replacement top board, fill level switch, and solenoids, all from another machine that was going just with stuffed bearings (apparently).
3 Suggested Answers
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 57 Answers
SOURCE: I have a Fisher and Paykel ECS Gentle Annie GW52-k
Make sure there is voltage going to the valve solenoids. That is what opens up and lets water into the washer. You will have to open up the top of the washer control. The valve assembly is where the hoses screw in the back. I don't have the technical on it but most likely should be 120V. Sometimes the valve goes bad and won't open up.
Posted on Feb 17, 2010
Gentle annie
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Nov 25, 2013 | Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
My washing machine is a hotpoint WF240. It started to overflow with water and spilling onto floor. We pulled it out from wall and found outgoing pump had fallen down, we put it back where it was supposed...
The machine will fill with it connected to the Electrical supply then stop if unplugged providing the fill valves/ water is okay....If it keeps on filling after unpluged then sounds like faulty fill valve,if on the other hand it fills without stopping when plugged in then its your air hose or Pressure switch at fault,Good luck
Apr 06, 2011 | Washing Machines
Hi Experts, I have a 1988? Fisher & Paykel GW51F top loading washing machine, and last week during the spin cycle, instead of draining & spinning, it just hummed for a few secs (draining, I...
Hi just read your posting.Is this machine a Gentle Annie model?Does the machine drain at all?The web address to watch the video of your machine does not work.Please reply with correct address and the name of your machine and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Washing Machines
My washing machine fills very slowly even though there is plenty of water supply. Sometimes the water only dribbles in. The worse time is on nthe rinse 2 cycle. Now it stops when the machine gets to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Fisher and Paykel (IWL12)
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Feb 17, 2010 | Washing Machines
Hi.I have a Gentle Annie that starts and stops filling with water
It is most likely the lid switch. The switch sits in a plastic bracket which has a lever coming down behind the tank.
If the tank sways and hits that lever, it cuts off the cycle as a safety measure. When the switch is faulty or more often when the plastic bracket breaks, you get this symptom.
Let me know if you need more assistance.
Ash
Oct 22, 2009 | Fisher Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
