What kind of power cord would be a good cord to up grade to for a TITAN space heater model number T76081
I have a TITAN space heater that has a problem with keeping its power cord cool the plug on it some times gets so hot it melts its self in to the plugin the cord just gets hot but doesn't melt. Can any body tell me what type of wire would be a good replacement ti eliminate this problem besides turning it off to cool down the heater is my work heater
  • Seth Quisler
    Seth Quisler Jan 03, 2013
    i never plug it in to the outlet directly i use a small high gauge extension cord as a safety guard for the outlet.
  • Seth Quisler
    i want to upgrade it with a grounding wire
SOURCE: worn out baseboard electric heaters
The only safe way is to read the voltage with a AC voltmeter. Turning off the power to that heater connecting the test leads and turning the power back on. There is only two leads going to the heater and you should always dissconect the power befor connecting the test keads. Your meter shoud be set to read the highest of the two voltages.110 Volts or 220 Volts. You might get lucky and find a name plate on the unit with the voltage shown.
Posted on Feb 27, 2008
  • 360 Answers
SOURCE: OVERHEATING OF THE PLUG-IN AND THE CORD IN GENERAL
Poor contact at the receptacle will cause the plug to heat. Look at the plug prongs for any sign of discoloration or arcing. You may need to replace the receptacle and/or plug.
Posted on Feb 05, 2009
SOURCE: the heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Posted on Aug 27, 2009
  • 103 Answers
SOURCE: my lakewood electric heater plug gets hot and
Sounds like heat element is defective drawing too much current. Make sure you are not using an extension cord on this heater, it has to be plugged directly into wall socket. Post model number on here so we know what unit we are dealing with.
Posted on Oct 09, 2009
shastalaker7
  • 1515 Answers
SOURCE: power cord overheating at outlet - melted cord a
Hi, what causes this could be a couple of different things. Yes, do not use this outlet until the problem is solved. Normally this is caused by your heater drawing more amperage then it was intended to do, due to a problem in the heater . Not knowing the age of your home, the electrical wiring through out may be the old aluminum wiring that has stopped being used due to the problem of this type of wiring heating up at outlets causing them to burn the insulation off of the wiring, burning out the receptacles, and in many cases in the past, burning down the home, not to to scare you. I will offer you some solutions to find out if your home is wired with aluminum wiring. Don't be afraid to do this for me. You need to find the breaker that shuts the power down to that outlet and area of the house. If you are not afraid to plug something into it for a few minutes and have a helper turn off breakers until you know it is dead. Once you have done this, take a regular or phillips driver and remove the 1 screw to take off the plate cover. Now, remove the 2 screws at the top and bottom of the outlet. This will take it loose from the electrical juntion box, so you can get a look at the wiring and damage to this. Normally, you will see any where from 3 up to six wires depending on if its what we call the start of the run, middle of the run, and so on. Wire colors will be black for hot and white for neutral. You will know if the wiring is copper or aluminum. If you think you are up for this, you can change this yourself. A new outlet is about $1.19. 1st, buy a couple so you will have a spare. The newer ones have screws on the side, and on the back have quick connects to strip the insulation back and just plug and push into a small hole that locks the wires. Facing the plug, black should be on the left side and white on the right. Another way to tell on the new plug is the color of the screws that hold the wires in place. Look at it and on one side the screws will be brass in color which is for the hot black wires. The other will be silver in color for neutral. If you find that the wiring is aluminum, there is nothing you can do but make sure all wiring connections are always tight! If you have to go through the complete home a little at a time to check all outlets only if they are aluminum, its worth the time! Do this once every couple of years or so and check and tighten, not so with copper wire. If copper, just check the one outlet. You can pick up a inexpensive pair of wire strippers and if the wire is aluminum, buy a small tube of nolox which is a gray paste they use on aluminum wiring to help keep it from oxidizing. Has different names, but you will find what you need in the same isle at home depot to do the job. Just cut off any brittle or hard wire and strip a 1/4 inch off the ends, either wrap around the screws on the side cw, not ccw, or use the quick connects in the back. When you are getting these items, pick up a new cord for your heater. Very easy to replace. Just follow where the cord goes into the heater until you find where the ends terminate and remove the old and install the new. You will have to have a few connectors and remove a cover on the heater, but really it is very simple. Just remember this, if the wiring is copper just get a new outlet and replace that and the cord. I believe this all started with that one outlet having loose wiring. If you don't feel like you can handle this, you still need to find out what kind of wiring you have so you are up on the dangers and consult a electric repairmen. I sincerely hope I have given you some direction to follow on this, and hope you will take on these minor repairs. Please be kind as I know you will, when rating this thread.
Sincerely,
Shastalaker7
A/C, Heating, & electrical Contractor
PS, just to say there will be a ground wire normally bare that will connect to a screw on the corner of the new plug, depending on the age of your home also. If no ground wire, leave it blank :))
Posted on Oct 20, 2010
Whirlpool 30 gallon gas hot water heater. does it have a battery
Need the model number to know for sure. I don't know of any waher heater that uses a battery. What is it that makes you wonder if there is a battery?
Jan 23, 2018 | Whirlpool Water Heaters
I have a Titan water heater model N-160. I turned the water off hoping to change the filter. Now There is no hot water and the screen reads : STAND BY FLOW=OFF how can I reset it?
Hey Shawn..did you turn the water back on BEFORE cutting the electricity back on? Cut the breaker off,,, wait 3-4 minutes before restarting.. MAKE sure the water is on ALL the way...
Troubleshooting the Titan tankless water heater
SCR3 160 Titan Tankless Water Heater
Jul 02, 2017 | Water Water Heaters
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Repairing rival titan space heater
Albert, I have serious doubts that you'll find a suitable switch for your needs on this type of a unit. They just aren't available, unless you can walk into a hardware store and know just what you want. Otherwise, these things are made in China for the most part, and when they ship them over here, they don't ship replacement parts for them...
Dec 12, 2013 | Heating & Cooling
Cord on electric heater gets very hot
I've seen a couple different models of portable electric space heaters do this. These things draw A LOT of power - anywhere from 1000 to 1800 watts! Some models were built with an undersized cord for the job. It's simply too small, and overheats as a result. This is an unsafe condition. Stop using this heater, and repace the cord with the correct gauge wire.
Oct 16, 2011 | Dimplex Compact Electric Flame Stove...
Titan space coils need replacement where can i buy them?
Call Camp Chef 800-650-2433, as they stock parts for Titan Water Heaters. You'll need to have your Model Number handy when you do this.
Mar 18, 2011 | Heating & Cooling
The electric cord on our Duracraft heater model CZ-600 was very hot to the touch (closest to the plug) -- it burned so hot we could not touch it for more than a second. The heat was at maximum and we...
Look carefully at the plug's connectors to see if thewre is any scorching or otherwise burnt metal...electrical connectors tend to get hot due to the plug being loose(this causes more resistance and thus more heating). As a safe bet...the parts aren't expensive...I would replace both the power cord on the heater AND the outlet recepticle
Jan 17, 2011 | Heating & Cooling
In my 2004 nissan titan want to know if it has synthetic oil would it be a good idea to change back to regular oil what do you recomend
In that truck you can use a grade like regular[ 5-20] -[10-30] it wont hurt to change oil unless the manufactors call for it.
Oct 08, 2010 | 2004 Nissan Titan
After installing my titan N100 the breaker keeps tripping went from 50 amp breaker to 60 and still keeps tripping how do Isolve this problem?
You had an instant heater there before? Or a different type? Your breaker numbers don't mean anything to me, I need amps and volts, what is the amp? 30? and the volt is 220? Or are you in Europe?. And you had the four wires in there before? And you have all 4 wires on the heater line? And the heater is grounded? It should work. Unless it is not getting enough juice, but you already upped the amp. Let me know what you got.
Jul 03, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Cord and thermostat wiring damaged by heat and/or age, both separated by short in cord where they enter the metal housing, Sunbeam heater Model 3559.
with space heaters, the first sigh of a problem is the first sign it needs to be replaced. This is your family and home you are talking about. don't risk it.
Feb 24, 2010 | Lakewood Engineering&Manufacturing PHT150...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
