Question about Hunter 20531 Vista Brushed Nickel Ceiling Fan
Lights too dim
Lights com on brite and dim after 5 seconds
    Genius:
  • Hunter Master
  • 1,617 Answers
Make sure you have the correct wattage in the bulbs.
Posted on Jan 24, 2013
When switch headlamps from brite to dim they go out also drive light wont come on
First I would suspect the dimmer switch on the steering column or wiring in the column. Second I would suspect a bad ground wire or ground connection. Here is link to a forum where others are having lighting problems with daylight running lights. The whole DRL system is rather a complicated maze of relays and connections, any of which could cause your problem. The tip on the forum to get a wiring diagram form Autozone looks like a good deal.
Headlight Wiring Diagram 02 F250 DRL Ford Truck Enthusiasts Forums
Jan 31, 2015 | 2002 Ford F250 Super Duty SuperCab
I have running lights in the day when i turn my headlights on i have no dims but i have brites..
first check the light bulbs, I've seen case where both dims were burnt out. Some running lights use the hi beams, some with a resistor so they are not as bright in the day. then check the relays, many times there is another one of the same ## and you can switch them around to test.
Nov 29, 2014 | 2005 Chevrolet Impala LS
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
Dashboard lights come on then dim out, not fuses. Notice that they come on and stay on when it is warmer ourside.
hi!!
Check wiring, specially the plug on dimmer control, look for loose connector and ground, if OK, check dimmer switch resistance (brite = less oms, dim = more oms.) if no or uneven reading, replace dimmer switch.
Good luck,
Mar 30, 2010 | 2003 Chevrolet Impala
How to reset oil change light?
turn the key on and depress the gas pedal 3 times in 5 seconds
if it flash 2 times it is reset
Mar 05, 2010 | Chevrolet Colorado Cars & Trucks
My laptop l2000 screen is dim but i can see
the display backlight is burned out that is why its dark. it can be fixed but, the whole display has to be replaced..
Nov 13, 2009 | Computers & Internet
I have no dash lights in my 97 sunfire
HEADLIGHT SWITCH MAY BE GOING BAD check it for burned wires
Dec 10, 2008 | 1997 Pontiac Sunfire
Hunter 20531 Vista Brushed Nickel Ceiling Fan Logo
52 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
