Question about Exercise & Fitness
Proform Elliptical Console won't power up, beeped
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: e7sv elliptical just beeps can't set restance
Dear Sir:
Adjust the Reed switch attached is the diagram for adjustin.
2) Change the batteries by new ones, and clean very well the contact batteries.Tight the flexibles cable from keypad and connector.
3) Run the software calibration for easy diagnose and troubleshooting.
4_8_2012_12_54_36_am.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Apr 08, 2012
ercupa190
  • 12223 Answers
SOURCE: nordicktrack x3 console frozen and track stick at 40% incline
RUN the software calibration for easy diagnostics, troubleshooting, and fix it.
Go under the HOOD of motor and see the instruction.See the block diagram
God bless you
Posted on Sep 01, 2012
Proform elliptical
did you replace the batteries in the console? they do make a power adapter for them
Aug 20, 2014 | Exercise & Fitness
I have a 390 proform Elliptical and it's is locked up. When I get on it, the pedals are tight and I can not move them.
There may be a problem with the belt inside the machine.
It has to be taken apart to assess.
Jul 14, 2013 | Proform 395 E Elliptical
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
Proform 405 CE Elliptical display and Silent Magnetic Resistance control stopped working
1) adjust magnet with the bolt looses with a wrench, tight very well.
2) proof the magnet for attraction or repulsion with the magnet from your refrigerator, if NOT pass the test replace it.
God bless you
Jul 24, 2012 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Proform elliptical 10 ze won't turn on
Dear Sir:
1) Replace by good batteries new one 2) Clean very well the contact with contact cleaner spray from R.Shack.
2) Turn the flywheel untill passing for the reed switch,and adjust it see the diagram attached, and ready.
ernesto cuadra
Apr 03, 2012 | Exercise & Fitness
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
