Question about Maytag Washing Machines
The Washer part of our Maytag ML2000 stackable washer/dryer won't turn on
This is a stacked Neptune ML2000 washer/dryer combo. The dryer works fine, but when I press the "Start" button on the washer it is supposed to stay on until the end of the cycle. It won't stay on. I held the button down for a short time and the water begins to fill, but after about a minute, it stops.
  • rickkel Jan 17, 2014
    The problem was solved by replacing the electronic panel underneath the top of the dryer. A simple pull the old and replace with a new one. Easy fix.
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
SOURCE: Neptune stackable washer...
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
  • 20 Answers
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
Posted on Feb 20, 2009
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
aborcass
  • 2651 Answers
SOURCE: Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Posted on Mar 20, 2009
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
ML2000 stack model, washer is not draining or spinning in spin cycle?
Call a service repair agent. This is a problem that needs some dis-assembly to fix.
Oct 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Water wont drain all the way
I have the same problem and am trying to get it fixed. You can find good info here: http://www.applianceguru.com/
Search for the model name and number of you appliance. Good luck!
Aug 24, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
