Question about Coffee Makers & Espresso Machines
Load busting sound, then steam coming out from back of franke ecolino semiautomatic espresso machine
    Genius:
  • Coffee Maker... Master
  • 1,669 Answers
It sounds like a safety valve releasing. You probably have a clog somewhere. I tried to find a service manual on line for the ecolino machine, but no luck, only the Saphira is available!
Posted on Jan 03, 2013
z34aga
  • 137 Answers
SOURCE: Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: AEG ESPRESSO MACHINE
With the machine cold (or hot if you have the right implement and can keep your hands away from the steam) I would try to insert something like a pin or a small length of bicycle brake cable up the frother tube and see if you can free what probably is a plug of solid mik in the end of the frother. Sounds like a blockage, it may suddenly blast out steam if you free it and you have the valve open so watch out. If it's not that then I would take the valve apart, especially if the machine is making the right noises. I'm not farmiliar with AEG machines though.
Posted on Nov 06, 2008
  • 145 Answers
SOURCE: KPES100PM Espresso Machine - will not make espresso
While I am familiar with Kitchenaid espresso makers, I am not familiar with this problem. I would suggest calling Kitchenaid Customer Service, as you will have options under your Pro Line warranty. Their toll-free telephone number is:
1.800.541.6390.
Posted on Aug 08, 2009
  • 10 Answers
SOURCE: Lavazza point espresso machine no steam
Sounds like a clogged steam pipe or a jammed two-way valve. First, I would try unfolding a small paper clip and then stick it up the spout of the steam pipe. if this does not free up the steaming arm then it is most likely a clogged two way valve. Should you need service you can call 781-393-2929. we are an authorized lavazza distributor and service center
Posted on Aug 25, 2009
EsWorld
  • 1618 Answers
SOURCE: My Rancilio Epoca E1 espresso machine has no steam
It is possible that the reset connected to the boiler tripped.
Posted on Sep 29, 2009
I am attempting to make an espresso but upon trying the machine makes a strange pumping noise and no coffee comes out of the shower.
The question is missing details about the nature of sound.
Also one needs to know if the machine is new? Taken out after an extended storage?
What make and model? semiautomatic or Fully automatic?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 30, 2016 | Coffee Makers & Espresso Machines
Franke Evolution no milk being dispensed
May be the milk pipe between the fridge and machine is kinked.
Mar 03, 2015 | Franke Evolution
Hello, I purchased a small coffee shop. There is a Franke Ecolino Superautomatic expresso machine that came with it. The owner said that the mother board fried from a power surge. They sent out the board...
Work with the previous owner and find out where it was sent and any records of it being sent. If monies were paid have the credit card owner contact the credit card coompany and contest the purchase. If you want a new mother board you would need to post the make and model of the machine.
Dec 05, 2014 | Franke Coffee Makers & Espresso Machines
Franke evolution error steam supply
wich nr does appear? 030, 032?
Sep 06, 2014 | Franke Evolution
I have a Franke ecolino machine and i need to replace the switch for the motor that controls the up and down press?
the right hand panel needs to be removed. once removed you will have access to the brew unit. half way up the brew unit you can see the switch that is needed to be replaced. the switch is secured by a couple of screws. and attached by 2 control wires. from there it is a simple replacement of the switch. if you require further info. feel free to email me.. bob
Jul 07, 2014 | Franke Saphira Espresso & Coffee Maker
The boiler in my Franke ecolino coffee maker is over heating. Anyone have a solution?
you most likely need a new pressure stat/switch as it is what tells the elements to turn off and quit heating.
Aug 26, 2011 | Franke Saphira Espresso & Coffee Maker
Hi. Malfunction 4 on Franke Saphire coffie machine, What should i do ?
The temp sensor on the Steam block has failed, a replacement is required
Aug 06, 2010 | Franke Saphira Espresso & Coffee Maker
Franke saphira will not exit rinse unit, will not rinse the coffee head but will supply hot water and steam. but will not depense any coffee. help please. I have had a Franke Man out and he has no clue he...
The machine has two pumps - one for each boiler. Did the Franke man check both pumps were working. If the main boiler pump has failed, the machine will know that the rinse hasn't occurred and won't go any further.
Feb 16, 2010 | Franke Saphira Espresso & Coffee Maker
Franke ecolino
If anyone have service manual or any kind of electrical drawings of this Franke Ecolino Coffee machine please send to
emrah_turkkan@hotmail.com
Dec 18, 2008 | Franke Saphira Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
195 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
