Question about Turtle Beach Ear Force PX21 Gaming Headset
Wiring diagram need to know how to connect the wires from the headset into the amplifier back to cuircut board, I accidentally pulled them all out.
2 Suggested Answers
  • 68 Answers
SOURCE: wiring diagram for turtle beach headset x11
Are you really going to re-wire the headphones? that sounds like such an ordeal. not worth the trouble i found this site that sells the Turtle Beach X11 for like 30 bucks or less. save your self the trouble.
Posted on Jan 27, 2013
How are the speakers wired on a Motorola S9 HD bluetooth headset?
Regrettably we don't have wiring diagrams.
Mark
Motorola Support
Jun 23, 2015 | Motorola Radio Communications
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
I want to hook up a slim sub for my truck using this amp. how can I do that? Because this amp plays everything not just the bass
You will need to connect the low level input leads from the head unit to the amplifier (they are RCA cables). If there are no low level leads from the head unit, you will need to connect the wires from the speakers directly into the high level inputs using a wiring harness which should have been included with the amp. It should include a wiring diagram. You will need to use that diagram in conjunction with the truck's wiring diagram in order to know which wires to connect. They are color coded and once you have the vehicle wiring diagram (which can be downloaded by searching for it on google.com), it should be easy to determine which wires to connect.
Mar 04, 2011 | Audiovox AMP610 Car Audio Amplifier
I accidentally stepped on the cord that goes Into the headset and it pulled on the cord and It just stopped working, please help me.
All that needs to be done is to check the continuity of the cord and fix it back to the section of the jack or the headset.
Most possible the wire would have stretched and so you will need a stereo cable that needs to be soldered into the jack and headset ,only if continuity is lost in the stretched wire .
Sep 27, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Center dash lights out.
Like stated above there are 3 small bulbs soldered onto the cuircut board. To replace yourself you must remove the radio bezel above and the shift bezel, these just snap into place though be carefull and always try to pull evenly to avoid breaking any tabs. The whole heater panel then can be pulled off. Unclip all the wiring harnesses, then unscrew the heater control itself from the panel. Remove the back of the heater unit to access the cuircut board. Remove the burnt bulbs by the base, slowly wiggling the base until they snap off. Go to radio shack and buy bulb #272-1141 (mini lamp 12Volts, 25mA). Remove the wires from the new bulb and melt off the glue on the base of the bulb with a lighter. Now you will have two metal leads exposed at the base of the bulb. Insert the leads into the base you removed from the cuircut board and slightly bend outwards so the base stays on. Dab a little bit of solder onto each of the prongs, then solder each prong onto the appropriate cuirtcut. be careful with the soldering iron not to touch any other areas of the cuircut board. I would suggest buying the long thin attachment for this procedure, as the prongs are small and the base of the bulb will be close to the cuircut board when soldering. This procedure is not for the novice, and if you are I would practice practice practice before you attempt to install the bulbs. I have done basic soldering before but nothing on cuircut boards, and I changed 3 burnt bulbs no problem, though I have to buy extra bulbs because on my first attempt I cut all of the metal leads off. Cost me about 5$ to do, since I already have a soldering iron. Good luck.
Jan 12, 2009 | 2005 Jeep Grand Cherokee
Xplod to a jvc
I would recommend using an 8 AWG minimum or preferably 4 AWG power and ground cable. Use as short a ground lead as possible and connect it directly to some chassis metal (avoid accidentally screwing into the gas tank if in trunk). Use a fuse holder with a 40 - 60 amp fuse under the hood within 18 inches of the battery. Your RCA cable coming from the back of the JVC radio should be run to your amp along with the remote turn on lead. This wire should connect to the JVC's amplifier turn on lead which should be a blue wire with a white stripe.
Aug 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Lcd has no power.
you can go to www.compassmicro.com to check if theres an available blueprint of the printer
Jan 22, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Need wiring diagrams for headset
I have the circuitry guide for the DSP box. I'm going to consider the top of the board the part with five connections, and the bottom is the part with eight connections.
From left to right on the top, the insulation colors are: red, white, green, black, no insulation.
From the left to right on the bottom, the insulation colors are: white, copper, copper/green, blue/green, red/green, red, copper/blue, green.
May 24, 2007 | Plantronics GameCom Pro 1 Headset
Turtle Beach Ear Force PX21 Gaming Headset Logo
Top Turtle Beach Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Turtle Beach Radio Communication Expert? Answer questions, earn points and help others
