Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
No ice is making but water will despense out of the slot and the filter is ok but not the best, the temp is cold and the ice despenicer is on i put water in to see it is fine what is wrong
  • mljohnson47 Jan 19, 2009
    ice maker won't run but there is water ready to come in if the ice maker would let it the moter doesn't run is there a senser that is not working?
  • liltrekkie Jan 20, 2009
    no but thanks for trying
  • 410 Answers
Check the i/m motor module the strippers should be in the 2 oclock pos normally if they are in anyother pos and not moving then you need whirlpool pt# 628366 good luck peyton
Posted on Jan 20, 2009
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
No Ice
Clogged filter?
On most ice makers, if the water pressure drops too low, the valve will not open to fill the ice maker.
Frozen water line?
On some units, the water line supplying the ice make can freeze up preventing water from getting to the ice maker.
Freezer cold enough?
Are you sure of the temp inside your freezer?
Place a small thermometer that can register temps around the freezing range. (example of a thermometers not to use are: a candy thermometer or a thermometer used to take a person's temp.) If you do not have one or do not want to purchase one, put a bowl of water in your freezer. If the water does not turn to ice in say 6 to 8 hours, your freezer is not cold enough.
Feb 21, 2008 | Refrigerators
No water pressure for ice maker or water despenser
Sounds to me that you attached a bulet piercing valve to a cold water pipe. If you did I would say the tiny hole that the valve put into the pipe has blocked up and causing your low water pressure. I have sen this problem a million times with that type of valve. You could try to close the valve and then open it back up. Sometimes this will clear the hole. If not I would replace the valve with the type of valve you have for your sink. there better in every way. You may need to have a plumber do the job for you but you will never have this problem again. Good luck
Jul 12, 2007 | GALAXY Microsystems 25.4 cu. ft....
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
