Dell Precision 5500 desktop will not turn on.
The switch on the computer does not turn on the unit. When I push tHe diagnostic button on the power supply it lights the green LED light on the back of the power supply and the fan runs. What can be assumed from this? Is it just a busted power switch?
  • Bill Jan 03, 2013
    More info: I have replaced the power supply. With either PSU the LED on the back of the power supply lights up green when I push the diagnostic button. At no time does the main power switch light up.
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
The leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty. Any bad or faulty power or data lead or connection can cause a computer not boot up.
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs Power and Data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power lead or fan lead can cause you problems computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Hope this helps.
Posted on Jan 03, 2013
5 Suggested Answers
  • 85 Answers
SOURCE: dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Posted on Apr 12, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
Chuck68
  • 42 Answers
SOURCE: Front panel Ac Switch failing to start computer.
Try these steps.
If Power supply light does not turn on (or no power supply LED)
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
NOTE: If the Power Supply fan spins when the PC is turned on but the light does not come on, it is possible the LED is defective. If this is the case, use the section Power supply light comes on or flashes .
1. Disconnect everything from the PC, including the power cord.
2. With the power cord disconnected, press the power button on the front of the computer. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
3. Replace the power cord with another power cord, like the one used by the monitor.
Test to see if the computer can turn on. If not, continue using these steps.
4. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
5. With the power cord removed, flip the red voltage selector switch to the opposite position, wait about five seconds, and then switch the red voltage selector switch back to its original location.
This ensures that the voltage switch is engaged and set correctly for your country/region.
6. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
7. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
8. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
9. Use a vacuum cleaner to remove the build-up of dust from the power supply fan vent holes. Make sure that the PC is turned off and that the power cord is plugged into a grounded outlet. Only use the end of the vacuum hose near the outside of the fan entrance.
10. If all of the above steps have been tried and the power supply light remains off, use the steps in the next section, use the next section Power supply light comes on or flashes , to reseat the cables and check the power switch connector.
Posted on Jan 12, 2009
  • 489 Answers
SOURCE: My Dell Precision 380's power light is orange
Check all of the electrical connections to all devices in the machine, especially the motherboard. Many times this is a result of a poor connection being jarred loose during a move.
Posted on Jul 07, 2009
Dell precision 670 diagnostic lights y g y
http://www.dell.com/support/Manuals/us/en/19/Product/precision-470
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
http://www.ebay.com/itm/DELL-H2703-PRECISION-470-670-VRM-VOLTAGE-REGULATOR-MODULE-TH-0H2703-WS470-WS670-/380369885440
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
Delll Precision M4500 plugged in. not charging
go to www.dell.com give your service tag and go to the support and download the diagnostic test software for computer batte. and fix it.
Your equipment can have installed too the software for diagnostic RUN and make the test.
God bless you
Sep 24, 2012 | Dell Mobile Precision M4500 Computer...
Dell Precision T3500 Press button to turn on the 1 & 3 amber lights blink a few times and turn off. The computer does not turn on. Checked all cables and tried cables from other computers in...
Try running diagnostic test press the power and the windows key at the same time and it will run in diagnostic mode and hopefully that will reveal the trouble. Also, you may wish to try reseating the memory.
Sep 06, 2011 | Dell Precision T3500 Computer Workstation...
Dell T3500 with E139765 on motherboard. LED on motherboard is yellow & system will not boot up.
Try the steps given below and it should resolve the issue;
1. Turn off the computer - unplug the power cable
2. Press and hold down the power button for 1 minute with power cable unplugged
3. Release the power button
4. Reconnect the power cable and turn on the computer
5. Dell ought to boot in Normal Mode
Lemme know the results.
Regards,
Anirban Mazumdar
Dec 04, 2010 | Dell Precision T3500 Computer Workstation...
My dell dimension computer won't turn on. When I push in the button, it only flashes orange and then won't turn on.
Plug the computer into a power strip that has an on/off switch. Turn the power strip on. Press the computer power on button to start as normal, but after after one second turn off the power strip switch just long enough for the fans on the computer to slow down, but the amber computer led doesn't turn off and then turn the power strip switch back on. Computer should start and run fine. Computer typically can be shut down for up to 5 minutes and restarted normally--any longer and you have to sue the power strip power switch routine again
Oct 25, 2010 | Computers & Internet
Dell precision 490 led 1 & 4 on
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Mar 29, 2010 | Dell Precision Workstation 490 - MT -...
Computers & Internet Logo
David Payne
David Payne
