Question about ASUS Computers & Internet
P8Z77-V red DRAM LED, NO VIDEO
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Check out video card
Posted on May 27, 2014
Dram Led on my motherboard blinks red twice
Don't panic. take a good light above your computer and start checking if every card and every connector is still correct inserted. Feel if nothing is lose. Even cards you did fasten with a screw, remove the screw and look and feel if the card was inserted correct. Everything you inserted in the motherboard should be checked. It could be a card you did not put in correct at the first time, but still made contact and only got lose because of some tension to shock.
Jul 03, 2014 | ASUS - MOTHERBOARDS Asus M5a97 R2.0...
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
ASUS P8Z77-VLK Intel Z77 Motherboard - P8z77vlk usb dirver won't install correctly
After you have run the installer, restart again. It's hardware software, mobo driver.
Aug 23, 2012 | ASUS P8Z77-VLK Intel Z77 Motherboard -...
Asus P8Z77-V Deluxe motherboard problem..Ram will only fit in single slots..e.g slots 1 and 2..Not dual channel.Will not boot as dual channel..Getting a Q-Code..55 Error reading....Meaning that memory is...
Get a second set of dual channel RAM from somewhere and test it in the slots and see if it still gives you the same error code. But most likely it will and you'll need to RMA the motherboard as the RAM slots are most likely BAD.
Jun 13, 2012 | ASUS P8Z77-VLK Intel Z77 Motherboard -...
Asus P8Z77-V Deluxe motherboard problem..Ram will only fit in single slots.1&2
Good Luck!
Red light on on my Buffalo HD
Red ERROR LED The way the unit gives diagnostic codes is by long and short flashes of the specific light. The number of long flashes give the first of two numbers and the number of short flashes give the second. For instance, one long flash and three short flashes would indicate an error of 13 -
E 00
(No light, beep only) - MPU error E 01 DRAM data line error E 02 DRAM address line error E 03 RTC chip error E 04 Flash rom error E 10 UPS power loss E 11 fan error (RPM too low or not functional) E 12 cooling error (unable to remove heat by the fan) E 15 disk error E 16 unable to locate internal HDD E 17 Unable to communicate with the RTC chip E 21 unable to communicate with the Phy chip E 22 mount error. The original Buffalo firmware has the following error messages based on the number of flashes:
3 Partition problem with hard drive. Reformat the hard drive. 4 Fan problem. 5 ROM problem. 6 Hard Drive can not be recognized. 7 Problem with motherboard (RAM, LAN, or Hard Drive controller). Exerted from http://buffalo.nas-central.org/wiki/Information/LSProLED
I hope this has been helpful, unfortunately without more information I cannot help any further.
Jul 20, 2011 | Buffalo Technology (USA), INC. - 500GB...
How do I clear the memory of received faxes without printing?
Try clearing the DRAM( Document memory.) Do the following.....
Press PROGRAM, *, G...(display should say "DRAM Clear".)
Press ENTER.
That should do it.
Nov 17, 2010 | Muratec F320 Plain Paper LED Fax
How do I clear the "received" memory without letting the machine print every received fax?
Try clearing the DRAM. ( Document memory.) Do the following....
Press PROGRAM, *, G ..( Display should say DRAM Clear.)
Press ENTER.
That should do it.
After Bios Upgrade Computer don't Boot
hmmmm you have currepted your DRAM, no problem try this file i think it will fix your problem.
Click here to download.
and try to write.
Thanks
Iqbal
Mar 16, 2008 | EliteGroup P4M800-M7 Motherboard
Printronix P5412 Do not Print
Sounds like this unit has some electrical (minor) damage.
Sep 07, 2007 | Printronix PrintNet Print Server
Computers & Internet Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
