Question about HP Deskjet D1420 InkJet Photo Printer
My printer won't print my documents
My printer is not printing my documents.
  • colleenmac51 Jan 28, 2009
    My HP Deskjet D1420 will only print partial documents, and if I type anything on Microsoft Word it will not print at all, it sounds like it's printing it and then the paper comes out blank?
Which printer???
Posted on Jan 19, 2009
Changed cartridge and now won't print a document
Verify the data cable or the PC printer setting,perform the test page,if you make a copy not problem the cartridge change.
Feb 25, 2013 | Canon Pixma MX410 All-In-One Printer
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
My computer says the printer is ready to print but when you try to print it won,t print and stores the document for printing later.
try to restart the print spooler from services.msc
start>run>services.msc look for print spooler then restart it
see if that helps
Mar 24, 2011 | Dell 725 InkJet Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Printer multiple page document
Try this only for windows user:
To resolve this, do the following :
  1. Windows 2000: Go to Start, Settings, Printers.
    Windows XP: Go to Start, Control Panels, Printers and Faxes.
  2. Right click on the printer icon and select Properties.
  3. Click the Advanced tab.
  4. Click the Print processor tab. The Print Processor screen appears.
  5. Change the Print Processor to Winprint and change the Default data type to RAW .
  6. Click OK in the Print processor screen.
  7. Click Apply, then OK.
Apr 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP Deskjet D1420 InkJet Photo Printer Logo
234 people viewed this question
Ben Johnson
