Question about Zebra MC9090-G Barcode Scanner
I am trying to connect to wifi, but it keeps say wifi unavailable? what could be the problem?
Warning Message: Regulatory - the profile you are trying to connect to may not connect due to regulatory issues.
Could not establish connection to network
have you been able to configure a WiFi profile using the on board utility?
If not and if you don't have the icon at the bottom right of the screen you will be able to find it in the windows folder.
If you have a profile setup, does it have a yellow ! icon on it if so, use the icon on the bottom right then> options > Regulatory in the drop down menu > and untick 'Enable...' box
If you have DHCP setup in the profile you may not be getting an IP address, you can check this in the status option from the pop up menu (bottom right).
if you are not getting an IP Address, check all your settings in your WiFi profile.
I normally start with a un-encrypted network to test the unit, then add encryption after you get it all working. You will need admin rights for the AP you are using.
Additionally i have found that some units don't like TKIP type networks with out a software update.
Hope this lot helps.
Sep 20, 2013 | Symbol Motorola MC9090 Mobile Computer
Tracfone displays the message network settings unavailable
What network is Tracfone supposed to be connected to? If AT&T , Verizon or other carrier you need to call technical support so they can program the network to your phone
Mar 23, 2013 | Cell Phones
Motorola MC3190 can not get ip address from dhcp on wep wi-fi
To configure the terminal TSD on Windows Windows do the following:
1. at the bottom of the panel find the network icon (it can be crossed with a red cross or be a red exclamation mark)
2. click on it with the stylus and select Options Options
3. In the window, select the menu and set the following values:
OP Mode Filtering - leaving only a tick AP Networks, and remove Ad-Hoc Networks
Regulatory - select the country (you can USA) and remove the checkbox Enable 802.11d
Band Selection - I chose only 2.4 GHz Band, 5 GHz mark removed
System Options - all ticks left (Profile Roaming, Enable IPv4 Mgmt and Auto Time Config)
Auto PAC Settings - AllowProvision ing AllowRefreshin g and both set as No
IPv6 - Enable IPv6 checkbox removed
Change Password - leave blank
Export - click the button Export Options, a window to save, note that saving should be in the folder \ Application and contain letters and symbols with the extension. Reg
After that, push the Save button and
Feb 23, 2012 | Zebra Symbol MC3190G Handheld Mobile...
How to enable Motorola MC3190 to access internet through LAN
Do you have Wireless Fusion on your machine?
If so, Enable Radio-->Scan for your WLAN-->Connect with a profile. If all settings are correct, and still can't get it associated, try disabling 802.11d from Wireless Fusion Menu-->Options-->Regulatory-->uncheck 802.11d.
Mine works after disabling this. Hope it'll work for you
Feb 07, 2012 | Zebra Symbol MC3190G Handheld Mobile...
Got a barcode reader Motorola MC9090-G and created a profile to connect to one of our available WiFi's. When trying to connect, "Regulatory" message is displayed and no connection is made at all. The OS is...
Hello, you would need to click on the wireless icon in the right down corner and select options, then in the dropdown menu please select Regulatory please select your country. If the issue persistslase uncheck also the 802.11d option
Aug 19, 2010 | Zebra Symbol Technologies MC909X-G Series...
Samsung star s5233w wifi problem
Hi... All you to do is clear all cookies, history and cache then restart your samsung star s5233w then connect to desire wifi connections. It always work on me using the same procedures.
Jan 11, 2010 | Samsung Star GT-S5233 Cell Phone
Can't access my facebook account..Need help!
i can't loggin because the network was interupted.
can you help this problem ???
thks
Aug 27, 2009 | Facebook Social Network
Can't connect wifi
do the following:
click on the mobile companion icon on the menu bar at the bottom. this is the radio icon.
click on options and from the drop down menu, select regulatory. uncheck the box 802.11d and select the country where you are.
save the options.
from the drop down menu again, select the last option called export and click on the export options button. save the default registry file and you are now sorted.
Jun 12, 2009 | Zebra Symbol Technologies MC909X-G Series...
Need WIFI Configuration manual for Mc3090. Getting error "The Profile you are trying to Connect to May not Connect due to regulatory issues"
Have to go to Fusion > WCConfigure> Options > Regulatory > uncheck ENABLE 802.11d,
I assume that Fusion is installed on all MC3090's but if not, you are looking for the wireless configuration options.
Apr 14, 2009 | Symbol MC3090
Symbol MC3090 Error while connecting
Uncheck the "Enable 802.11d" in the Regulatory segment of the Wireless Options.
Mar 11, 2008 | Symbol MC3090 Mobile Computer
Zebra MC9090-G Barcode Scanner Logo
29 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
