Question about Ace Hardware Living Accents Patio Heater Cover
Living accents outdoor patio heater model #4365508 / SRPU31 won't stay lit
The unit will light and stay lit as long as I keep pushing in on the control knob. The second I release the control knob the burner goes out.
  • Rick Sherman Jan 05, 2013
    I follow the lighting instructions: push in the control knob, turn counter clockwise to the "low" position and the burner lights. As long as I continue to depress the control knob, the burner stays lit. As soon as I release the control knob, regardless of how long I have it depressed, the burner goes out. It seems gas stops going to the burner unless the control knob is depressed. What is the cause and fix?
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
I have bosch pgl985uc burner problem. The center burner will not stay lit. Seems other have had this problem. I ordered all new thermo-couplers. Installed, since Bosch changed them to a new part number...
If The Burner lights and stays lit as long as the knob is depressed, but goes out after the knob is released then there is a failure with the thermocoupler or the valve itself. The thermocoupler can be tested once removed from the cooktop - as follows
Heat the tip on the thermocoupler with a match or lighter and measure the electrical connection (other end) with a voltmeter - it should read about 15 mV or slightly more with in a few seconds. If no voltage is read then the thermocoupler is faulty and should be replaced.
The valve coil can also be tested for continuity at while the unit is disassembled. If no continuity is found the valve is faulty and should be replaced
The small voltage created from heating the thermocoupler energizes the coil in the valve which in turn keeps the gas turned on while there is heat at the thermocoupler.
Some units actually reignite the burner if the heat is lost and the control knob is in the on position.
Hope this helps ....
Dec 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
My Sunjoy L-PH007PSS-B wont stay lit.
Blocked pilot too small needs cleaning , or clean end of thermocouple ,or replace thermocouple
Nov 02, 2012 | Uniflame Table Top Outdoor Patio Heaters -...
Tabletop heater won't stay lit
The first thing to go on a patio heater is the thermocouple, these are consumable items that need to be replaced depending on useage. Found this site very useful patio heaters problem solving.
Mar 25, 2012 | Heating & Cooling
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
Im not getting enough fuel pressure to create a decent flame, everything lights as it should and stays lit but its not letting enough pressure out. Could it be the pressure regulator on the line thats...
Check what type of fuel, if using butane on cold days it will stuggle to stay alight, always use propane on outdoor patio heaters, propane will work in vvery low temperatures. If using propane check for leaks, do a leakage test, found this patio heater specialist site very useful.
Feb 21, 2011 | Endless Summer Blue Rhino 235000...
Searing Unit Keeps Cutting Out After Release of Knob
First I have a couple of questions for your question on how to fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free: (800) 468-5252
Local: (972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 10, 2010 | Brinkmann Stainless Steel All-In-One Gas...
Ace Hardware Living Accents Patio Heater Cover Logo
219 people viewed this question
Top Ace Hardware Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Ace Hardware Pool and Spa Expert? Answer questions, earn points and help others
