Question about HP Photosmart C7280 Printer
Hp c7280 printer please insert memory card - HP Photosmart C7280 Printer
sagarjd
  • 95 Answers
SOURCE: hp photosmart C5250 all in one
Thank you for the information
Please check if you have inserted any Memory Card into the All-in-One.
Please perform the following steps:
1) Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Please perform the following steps to reset the printer to factory settings.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord
Regards,
Sagarjd
Posted on Jul 27, 2008
leroyal
  • 2120 Answers
SOURCE: How do I get rid
Unplug the power cord for 10 seconds
Posted on Jan 18, 2009
SOURCE: memoy card error
Im using XP and have the same problem. I have no Memory card in the slot. How do you clear this error?
Posted on Dec 25, 2009
  • 44 Answers
SOURCE: My HP C7280 wireless printer is "ofline" how do I
Go to printer folder ( printer and faxes ) right click on the printer and choose " USE PRINTER ONLINE"
Posted on Nov 14, 2010
fbibeau
  • 66 Answers
SOURCE: HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Posted on Mar 04, 2011
C7280 diagram hp parts
doesn't have that kind of memory that stores stuff when pwr is turned off.
Oct 19, 2013 | HP Photosmart C7280 Printer
How do i get my hp photosmart c7280 back online i have a print job but says printer is offline - but it is connected
remove and insert the cable in another usb port.if the problem continues change the usb cable and try
Aug 05, 2011 | HP Photosmart C7280 Printer
Printer will not recognise camera memory card hp p315 photo printer
Was your Lexmark P315 printer able to detect this particular memory card before? Try to re-insert the card - it could be due to a slight communication problem. Have you tried inserting a different known working compatible memory card into the printer's card slot? This could be due to faulty memory card.
Also, please refer to Memory Cards Supported by the Lexmark P315 Photo Jetprinter.
Jul 26, 2011 | Lexmark P315 Photo Printer with 2.5" LCD...
HP Printer C6280. It has power, when powered up, the LCD flashes the HP logo then goes blank. Not initializing the scanner or cartridges.
Have you inserted a memory card? The LCD menu may not activate until a memory card is inserted. If a memory card has been inserted the printer may have goe into sleep mode while reading the card information.
See here for information on compatible memory cards and memory card issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00059994&cc=us&lc=en&dlc=en&product=3194498&tmp_track_link=ot_search#N1954
Dec 18, 2010 | Office Equipment & Supplies
I cannot scan document and attach it to the email. Please help. I have wireless HP C7280 printer and scanner and Mac PC. thanks!
depending on your scanner lay the document to be scanned face down scan the document at the end it will ask you what format to be saved in select color i found if you select grey scale it comes out blury then save it in my documents/my pictures create an email click insert file attachment select browse to this document then attach it done
outlook express
hope this helps
Oct 23, 2010 | HP Photosmart C7280 Printer
Having a problem with the scan function on my HPC7280
Not too sure on this model, but if there was no options, perhaps the machine has not been set up correctly to scan to a folder or application.
This FAQ/Guide from HP shows you what you need to do to correct set up your printer to make scans.
Dec 11, 2009 | HP Photosmart C7280 Printer
How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
I'm sure 100 works!
Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
Can't download to computer from memory card
there should be 2 to 4 inserting ports in the printer for memory card, so you have to just insert the memory card in right port and there is also some type of jecks for memory cards to insert them in card readers.
Apr 13, 2009 | Computers & Internet
HP Photosmart C7280 Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
