Question about Zebra 105Se Thermal Printer
Zebra 105SE My printer prints blank labels, seems like the ink didn't get transfer onto the label. The ribbon is installed correctly and I didn't change anything on the printer. Please help!
  • 186 Answers
Make sure the ribbon is installed properly. The thermal ribbons are only coated on one side with ink. Make sure the right side is facing the paper. If that is not the issue the thermal head might be bad.
Posted on Jun 26, 2007
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
Feb 02, 2008 | Zebra Z6M Plus Thermal Label Printer
I switched a Zebra printer from one computer to another. It used to print on the previous computer, but it will not seem to print on the one I switched it to. Do I need to install the printer? I do not...
You need to install the printer driver for Zebra 105Se as well as label software (if you are using it). If you are using label software, BE SURE TO USE THE DRIVER PROVIDED BY THAT MFR, as they are not interchangeable. If you are not using label software, use the ZDesigner driver from the Zebra website.
Jun 13, 2011 | Zebra 105Se Thermal Printer
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
TLP-2844 ink not thermal-transferring (labels are blank)
Ribbon is probably not installed correctly. Call Andrew @ 908-725-1699 for free tech support
May 05, 2009 | Zebra LP 2844 Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Printer Stripe S-500 Zebra
Question, when the printer prints is there an image of the data on the ribbon when it spools onto the ribbon takeup spool? If so, the ribbon may be installed backwards. I'm sure you know what you are doing but one must check even the smallest detail when trying to solve these strange problems. If the ribbon is installed correctly and there is no image of the data on the ribbon you may be dealing with a bad printhead and the printhead needs to be replaced.
Dec 19, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra 105Se Thermal Printer Logo
259 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
