Question about Water Pump for 03 2003 Ford Excursion Bosch
I have the code p0316 on my ford excursion
The radiator went emty
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 50 Answers
Posted on Oct 12, 2013
What are the probable causes of DTC P0316?
The P0316 DTC code is a generic code that applies to all vehicles. This code means the powertrain control module (PCM) has detected a misfire shortly after startup, specifically within the first 1,000 revolutions. This code may also be triggered with another of the other misfire codes which are P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, P0309, P0310, P0311, P0312. If you have another misfire trouble code also, you should diagnose and repair that code(s) first. Symptoms Symptoms of a P0316 DTC may include: MIL (Malfunction indicator lamp) illumination Rough engine start or idle Potential Causes Potential causes of this misfire code may include: Damaged or defective Crankshaft Position Sensor (CKP) CKP sensor wiring or connector fault Poor fuel quality Ran out of fuel Ignition system malfunction Fuel system malfunction: injector or fuel pump Mechanical engine problem Damaged PCM Possible Solutions First off, you'll want to repair any other misfire DTC codes if present prior to diagnosing this code. If you own a Ford vehicle and you have a P0316 along with one of the other misfire codes, you should check for appropriate TSBs (technical service bulletins), as there are some TSBs that in part involve reprogramming the PCM. Doing that requires specialized equipment. Some Ford vehicles even needed a new cylinder head as a result of the valve. Regardless, if you have a Ford with multiple misfire codes including this one, check for TSBs. If the P0316 is the only code, then it's time to do a bit more diagnosing of the crankshaft and camshaft position sensors, and their associated connectors and wiring. A tip we've found is "Since this code indicates a start up misfire, pay attention to items which may expand or contract when cold (if the code sets when the engine is cold), or hot (if the code sets on a hot restart)." Realistically, the freeze frame data from the PCM will be helpful in tracking down the problem. As will a good DVOM (digital volt-ohm meter), so you can perform tests on the wiring and the sensors.
Read more at: http://www.obd-codes.com/p0316
Copyright OBD-Codes.com
Dec 10, 2015 | 2003 Ford Taurus
2003 ford focus codes p0316,p0300,p0302,p0303
I had a similar problem with my '02 Focus. I found the actual wires leading to the harness had broken. From the codes I would say you have lost a good connection with cylinders 2 and 3. My Focus started to hesitate and jump until normal temps were reached. Then it jumped and hesitated all the time. I went to the junk yard and got a replacement wire set for $3. I cut the current ones out and used heat shrink and electrical tape to reconnect the new. Worked like magic.
Here is an excerpt from the code problem below. Good luck
- Ignition coils harness is open or shorted
- Ignition coils circuit poor electrical connection
Read more: http://engine-codes.com/p0300_ford.html#ixzz3AEUWtCDs
Mar 25, 2014 | 2003 Ford Focus
Code p0316
Code 316 is an extension of your Code 304. 316 means its misfiring in the first 1000 RPM's and 304 means number 4 cylinder is the problem cylinder.
Could be a bad wire, coil, or sparkplug.
Jul 08, 2013 | 2009 Ford F-150
My ford 2003 excursion is having a lot of problems error p0316 what does it mean?
when you first start it is misfiring on one or more. i would get a tunup if you havent yet. spark plugs and gas filter.
Jan 03, 2013 | 2003 Ford Excursion
I have 3 codes. P0172, p0316 and p0316. It is misfiring under 1000 rpm. after 1000 rpm it runs great
p0172 Basically this means that an oxygen sensor in bank 1 detected a rich condition
p0316 crankshaft position sensor
clean your intake and check you cap / rotor
Dec 24, 2010 | Ford Taurus Cars & Trucks
2002 ford f150 xl 4.6 litre code p0316
Do you have another code in addition to this ?
The P0316 DTC is Misfire Detected On Startup (First 1000 Revolutions), which usually has another code set in addition to the P0316 code.
Nov 15, 2010 | 2002 Ford F150 Regular Cab
Dtc code p0316 on 2002 ford taurus
Code P0316 means 'misfire detected first 1000 revs.'
Feb 18, 2010 | 2002 Ford Taurus
P0316 scan code come up on my 2002 mustang 3.8
The Ford troubleshoot code P0316 = Engine Misfire Detected on Startup (First 1000 Revolutions)
Check for moisture under a coil. It seems to be a somewhat common problem.
Sep 30, 2009 | 2002 Ford Mustang
Water Pump for 03 2003 Ford Excursion Bosch Logo
Top Bosch Vehicle Parts & Accessories Experts
xxxxxx xxx
Rob Beech
Andrew Gaitan
Level 1 Expert
Are you a Bosch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
