Lost remote I lost my remote and wanted to know if there is anyway to change the input source on an Ilo tv (model LWT3206) with out having to purchase another remote?
tvtek
  • 1284 Answers
SOURCE: How do I change the input without the remote
If there is no nutton on the TV to do so then you have to have the remote for it. You can try a universal remote but, usually functions like that don't work. Here is a link to the remote you need. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6450348129
Posted on Feb 23, 2007
ebrus
  • 30 Answers
SOURCE: Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 28, 2008
nickstorm
  • 93 Answers
SOURCE: how to change the input
First, the bad news: Unfortunately, you are correct - the only button to change inputs is on the remote, which you no longer have.
Now, the good news: You can buy a universal remote, set it for your TV model, and have control of your inputs again. The first link below is for the URC R6, which is available at any Walmart for about 20 bucks. You can set it up for an Emerson TV, no problem. Here's the link for it:
http://www.universalremote.com/consumer/products.php
Also, here is a link for the owners manual to your Emerson EWF2703, in case yours has gone missing with the remote:
http://www.emersonaudiovideo.com/pdf/om/EWF2703.pdf
Not a perfect solution, but it will work, and it will work just as fast as you can get to your local Walmart or equivalent.
Cheers
Posted on Nov 05, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
SOURCE: rca rt2390 lost remote 5 years later lost
I found somewhere called newremotecontrol.com they have the remote for less then $20 bucks ... I lost my remote 3 years ago
Posted on Apr 19, 2009
I have an ilo television and have lost the remote so I cannot access the auxillary channel to use my DVD player.what can I do?
You need to get the original remote for your TV (WWW.REMOTES.COM) to get complete full functions of the remote.
Model number of the TV?
You may have to look for 'INPUT' or 'SOURCE' button on the TV. If it does not have them, then you can try hitting the channel button to get to CH2 and go lower to see if AV1, AV2 will come up on the screen.
Jan 27, 2011 | Televison & Video
Girlfriend lost remote for RCA F27645. I know I
If I'm Correct There Is Only One Set Of Inputs On That Model TV. What Inputs R U Reffering To?
Jul 12, 2010 | RCA F27645 27" TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
I lost the remote and can't change the channel to
If you cant purchase a new remote then you may want to try buying a universal remote and program it to your TV.
Aug 03, 2009 | iLO Televison & Video
Need remote codes
You may be able to get help here. This is a link for the owners manual in PDF.
Hope this helps!
http://dukeelectronic.com/Manual/IWT3206.pdf
May 30, 2009 | iLO IWT3206 TV
Need to put tv on video 2 mode to use ps3 and no remote
Have you tried running through the channels until they wrap around and start over again? Alot of TV's will throw the AV inputs in there before the first broadcast channels.
If not (and you're gonna hate my answer, but be kind to the messenger please!), you may have to purchase a new remote control from the manufacturer, which can be exorbitantly priced. Most 'Universal' remotes will act just like your Dish Network remote, and you will probably not be able to use any of your set's advanced functions through them.
I would recommend searching the web for the appropriate replacement remote control, you may get lucky on eBay and save a few bucks. Hope this helps!
Jan 09, 2009 | iLO 3200 32 in. LCD Television
We need a new remote for our ilo TV in order to hook up a DVD-VCR player!
First off you will need a remote that has the ability to operate your ILO TV. www.remotes.com has a replacement that will work for you. As you will need to access the inputs for your TV to receive the signal from your Philips unit
Oct 10, 2008 | iLO 2600 Television
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
A/V INPUT
You need to purchase either a replacement remote from ORION or Ebay, OR you can purchase a replacement universal remote and program it for your TV. Make sure the Universal remote you buy has an input or source button. Radioshack carries several for 8-15 bucks.
Feb 03, 2008 | Orion STV2763 27" TV
Ilo 27" flatscreen
I moved and the manual and remote got lost. I bought a ONE FOR ALL remote that has the iLO printed on the add but I can't get the tv to work, I tried all the codes but nothing worked. How can I get a manual from the computer to work this iLO tv, which I am unable to use. Maybe I should have purchased a Sony.
Sep 30, 2007 | iLO Televison & Video
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
