Question about Electrolux E24WC48EPS Wine Cooler
E24wc48eps electrolux 48 bottle wine fridge.
The light works but it stopped cooling! Is the Thermostat broken?
5 Suggested Answers
SOURCE: Fridge not working
Fridge not working,regulator is under repair.can u suggest the services in hyderabad.
Posted on Feb 18, 2008
SOURCE: we have caravan electrolux rm
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Posted on Jul 08, 2008
hiltonjug
  • 612 Answers
SOURCE: ice formation. double door electrolux fridge. not cooling
If there is ice built up on the inside back wall of the freezer, you have a defrost problem. Take the panel off, use a hair dryer to defrost. If you know how to use a meter you can check the heater and termination thermostat. One is most likely bad. If you cant use a meter. Put panel back on and plug fridge back in. It will work fine for around three days. This will give you time to get the part or someone out to fix and you will not loose your food.
Please rate solution
Posted on Aug 27, 2009
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
I have an NEC refrigerator model FR480 eight years old that has stopped cooling. Called the technician who can't get information with regard to the electronic controls. It appears that the compresor and...
Hi, do you mean the signal to stop cooling is faulty?
I guess the thermostat is faulty. Its the one which detects the temperature and send signals to the circuit.
Oct 10, 2008 | Refrigerators
Our thermostat stopped working -why?
You did not give any information. is it battery operated. if so battery could be dead. Could be a loose wire. Wire from furnace could be loose. does wires go up in the attic? could be a broken wire. Thermostat may need replacing. you can check to see if thermostat is working disconnect the wires off of thermostat and touch the furnace two together and hold for a bit. If the furnace starts up you know its the thermostat.
Jun 29, 2017 | Heating & Cooling
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Jun 07, 2016 | Furniture
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Wine cooler power on but not cooling ...have tried to set controls but compressor is not kicking on ....unit is not that old
Try changing the relay inside plastic box on compressor
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced
Reattach the wire to the new compressor relay and press the relay back onto the compressor terminals. Replace the terminal cover box and plug in the refrigerator.
Jun 03, 2011 | Electrolux Icon 48 Bottle Wine Cooler Free...
I'm not totally sure this is my model number but my fride seems to be involentarily stopped working...its on but its not cooling...help!
check that there is power to it first then check the thermostat is still working,,if the thermostat has broken down the freezer wont run at all
Aug 25, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Heater quit
Thermostat regulates coolant temp so that the engine doesn't run too cool, It has no effect on the heater temp once the engine has reached operating temperature. Check that the hoses running from engine cooling system to the dashboard are not blocked, bent or broken. (Actually if broken, engine would lose all coolant fluid, and you would notice the mess). Check that the heater switch is doing its job, and actually activating the heater. All that said, If your car happens to have NO thermostat, engine will never reach a normal temp, and the heater will not work.
Dec 08, 2009 | 1996 Geo Metro
Electrolux E24WC48EPS Wine Cooler Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
