Question about Seagate Barracuda 7200.7 160 GB Hard Drive
Trying to repair windows xp on a Seagate Barracude 7200.7 160gb SATA HDD
  • coupondeal
    coupondeal May 11, 2010
    OK. How did you do?
  • Alex M
    Alex M May 11, 2010
    You said: trying to repair windows xp on a Seagate Barracude 7200.7 160gb SATA HDD ,,,,can you be a little clearer here???
    just what is your problem?
    President:
  • 1,996 Answers
Can you pleae be a little more explicit? What is the make & model of your computer? What kinds of repairs are you trying to do? What kinds of errors or symptoms are you experiencing?
Posted on Mar 27, 2009
3 Suggested Answers
  • 46 Answers
SOURCE: how to tell which jumper is master and which is slave
normally most harddrives are the same, copy the other one see if that works.
Posted on Mar 28, 2008
lserni
  • 466 Answers
SOURCE: Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Posted on Nov 25, 2009
My windows 7 Home will not read my new Thermaltake BlacX Duet. Downloaded new driver and still no luck. Anyone have some suggestions? Im not a programmer, but can follow instructions. Thermaltake web
try with knowingly functionating hdd, also hdd sometimes will not display in my computer due to partition error, but will display in control panel- administrative tools - computer management - disk management , new hdd-s might do the same because they only have unallocated space,and need formating. I don't know if the device itself should display itself or not, check in device manager but maybe its normal that its invisible and shows only hdd-s. If a hard disk has malfunctioned to an extent, you will not see it anywhere in windows
hope this helps
Sep 17, 2014 | Thermaltake Blacx Duet St0014u 2xhd Sata...
I had windows vista and tried upgrading to windows 7. the upgrade failed (it was a download from windows) and it tried to resort back to windows vista however that failed. Now the computer wont start...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
Mar 18, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Windows xp will not recognize my seagate barracuda 7200.10 although it is recognized in the BIOS. I pressed f6 during setup and it is asking about the Manufacturer-suplied hardware support disk. Where...
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
Jul 30, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
I have a gigbyte GA-MA790XT-UD4P mother board that when I try to install XP on a new Seagate 1TB Barracuda HDD, that it won't recognize during the install process
If your hdd is sata and you have an old mobo , windows xp (onlycvista will) will not recognize it. Integrate sata in xp (use nliteand goolgle how to) or use the flloopy disk to run sata driver
Mar 29, 2009 | Gigabyte GA-K8VM800M Motherboard
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.7 160 GB Hard Drive Logo
96 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
