Question about Brakes for Toyota Land Cruiser
Left front brakes locking up on 95 landcruiser
  • 1 more comment
  • Peter Kelly Jan 05, 2013
    Thanks Thomas, all
    Thanks Thomas, all
    Thanks Thomas all pistons were free when pads replaced, brake lock comes on intermittantly when does happen it comes on without the brake pedal being depressed i have just bled the system and will post if any change.
  • 43 Answers
Sorry, a worn or warpped disc will not cause a locking. Most likely:
1 As above, sticking piston in the RF caliper
2 Collapsed RF brake hose
3 Much less likely- ABS distribution valve assy
I am making certain assumptions. The brake locks only when applied hard? Is it really locking or simply pulling hard as in jerking the wheel?
I hope that I am on the right track for you.
Posted on Jun 04, 2016
  • Toyota Master
  • 14,379 Answers
Your brake caliber could be sticking,the piston is bad,when replacing,it's best to replace both sides.Her's how to replace if they need it.Also check your Disc for wear,could be that,check brake pads wear,both sides should be wearing even.
Posted on Jan 03, 2013
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
2006 Hyundai Tucson 4wd 2.0L experiencing brake fluid not flowing through the left front wheel line, brakes locked up
if it is locked up on the front left side only , it sounds like the caliper is stuck , remove caliper and see if you can squeeze it in with a large c clamp .. may be hard to remove if it is stuck on caliper . replace with rebuilt if it is locked up then rebleed
May 24, 2015 | 2006 Hyundai Tucson
LSpecifications on how to rebuild/repair landcruiser rear differencial
you must first afereseis the brake system after the two axes moves right and left (for releases the differencial). Take out the screws perimeter from the differencial and take off .
began to assemble in reverse.
Sep 28, 2014 | 1971 Toyota Landcruiser
I have a 95 Villager with Anti Lock Brakes. I replaced the Pads, Calipers, Shoes and Front Brake lines. I bled the brakes according to the repair manual but, the brake light is on and the pedal still goes...
The brake bleed may not have been successful. Always bleed the right rear brake first then the left. Next the front right and then the left. If you are using someone to work the brake pedal make sure they hold it down until you have closed the bleed nipple. Make sure you use a little hose on the nipple and into a jar with fluid in it to watch for the bubbles to stop. Make sure the master cylinder always has enough fluid in it.
There is a brake bleeding kit that can be bought, this makes the job a lot easier.
Oct 07, 2011 | 1995 Mercury Villager
My abs light is on. what is it to be done?
abs is anti-lock brake system
need to take to someone that works on brakes and have them check it and see whats wrong.
would not drive it very much untill you have it checked because the brakes can fail.
Jul 27, 2010 | 1995 Toyota Land Cruiser
Left front brake locked up. Changed master cyclinder. Have good brakes for an hour then left front keeps getting air in line. No visible leaks (wet spots).anywhere also no lose of fluid.
If left front brake is binding it will cause brake fluid to boil which inturn causes air in system, then soft pedal. [may also explain lock up].
Sep 03, 2009 | 2002 Hyundai Accent
95 G20 Chevy van: ABS light stays on, pulls right when braking
You actually have two separate problems. The brake pull to the right is indicating the left side brake is not working properly. You will want to remove the left front wheel, collapse the caliper piston and make sure the caliper is floating freely on its mounts.
With the piston collapsed you should be able to slide the caliper inboard and outboard of the rotor. If not, you will want to remove the attachment pins, clean and lubricate the pins. If they are grooved or worn you will have to replace them.
The second issue of the ABS light is indicating the system has detected an electrical sensing or control problem. Take the vehicle to your local Auto Zone or Advance Auto and ask them to scan the vehicle for trouble codes. They will scan it for you at no charge.
Chances are you will find a wheel speed sensor problem at one of the wheels.
Write the codes down and respond back, we can start diagnosing the problem,
Good luck, let me know.
Regards,
Aug 31, 2009 | 1995 Chevrolet G20
Brakes for Toyota Land Cruiser Logo
85 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
