Question about 5901 Security Remote Start System
Transmitter shutdown I installed a bran new battery in my car and now my remote doesn't pare, or start or closes the doors and i have the shutdown errors 4 transmitter shutdown 5 (+) brake shutdowne
2 Suggested Answers
logosc75
  • 625 Answers
SOURCE: I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Posted on Aug 20, 2012
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Key fob
Walk out to the vehicle with a new battery in the key fob and press the lock AND unlock button at the same time while you stand close to the vehicle for 7 seconds. You will hear the doors go thru a lock and unlock cycle, your fob is now programmed. This will sync existing programmed controllers, security sync. to program new remotes:In the trunk, connected to the wireless remote controller (driver side on wheel well, need to remove 'mat') is an empty connector with 2 wires connected. short the two connector pins. The locks will all cycle. Press and hold lock/unlock buttons on remote until locks cycle on/off. repeat for other remotes. Remove short across connector pins. Test new remote(s).Warning:existing remotes are deprogrammed, only remotes programmed will work from now on.This worked on my 1998 Cavalier. Be sure battries in new remote(s) are good! Answer Locate the data link connector under the dash (under the steering column). Ground out pin #8 of the DLC (top right port) with a jumper wire to any piece of metal close by (I use the e brake hardware). The door locks will then lock & unlock to let you know you are in the programming mode. Simultaneously press & hold the lock & unlock button on one of the keyless entries until the locks cycle (this lets you know the transmitter has been programmed). Repeat this step for your second transmitter. You must reprogram the 2nd transmitter within 60 seconds of programming the 1st one or you have to start over.
Note
Read more: http://wiki.answers.com/Q/How_do_you_program_a_keyless_remote_for_a_1996_Chevy_Tahoe_LT#ixzz1wjwEcG4s
Jun 03, 2012 | Oldsmobile Cutlass Supreme Cars & Trucks
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
Nov 01, 2011 | 2004 Lexus ES 330
I replaced batteries in keyless remotes for 2002 chevrolet monte carlo ss. how do I resynchronize the keyless remotes?
Hello: To resynchronize the keyless entry close all doors, key out of ignition. Hold lock and unlock buttons till the doors (all) lock then unlock. If the transmitter still doesn't work you have other problems. Go to auto zone they can check your transmitter to see if it is working.
Oct 24, 2011 | 2002 Chevrolet Monte Carlo
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Replaced batery in key fob and now there is no connection between fob and security system...I can lock and unlock doors with the key and I can start car ...fob doesn't work; does not lock or unlock...
reprogram the remote transmitter. first leave driver door open all other doors closed,key removed from the ignition switch. insert key into the ignition switch,then remove it.press lock and unlock on the vechicle door lock control switch at 1 second intervals 5 times. close and repoen drivers door.press lock and unlock on the vechicle lock control switch at 1 second intervals 5 times. insert key into ignition switch. switch ignition on and off twice to program a remote transmitter code whilst erasing the original codes or three timre to check how many remote transmitters are currently registered.remove key from the ignition switch.system should now lock and unlock.twice to indicate programming mode or one to four times,slowly to indicate number of remote transmitters registered.for the solara press and hold lock and unlock remote buttons together, press lock remote button for a second period of 1 second. system should now lock and unlock vechicle.once to confirm, twice to indicate registration has failed.if required repeat button procedure to program remaining remote transmitters.note to exit programming mode close drivers door or insert ignition key.maximum of 4 remote transmitters can be programmed.if akk failed let dealership reprogram remote transmitters.
May 18, 2011 | 1999 Toyota Camry Solara
I have a problem with opening car doors with remote for 1997 pontiac sunfire. I noticed that when you are in the car and you activate the open and close switch from drivers side the locks at the rear open...
Try this procedure...
KEY FOB PROGRAMMING INSTRUCTIONS
Transmitter Programming
No Tools Required
In the event that a transmitter is lost, program the old & the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If u program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver is seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle is doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body & Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open & then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If u do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press & hold the transmitter LOCK & UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body & Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1997 Pontiac Sunfire
Remote start function on remote doesn't work for a 2005 Pontiac G6.
Replace battery first and see if that help, if not then follow steps below, if you cant figure it out or it still doesn't work, or take it to the dealer, it could be remote module is faulty. Keep the windows open as a safety measure, then,
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
Close all of the doors.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, & then back to ACC within 1 second.
Open & close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
Oct 07, 2009 | 2005 Pontiac G6
5901 Security Remote Start System Logo
55 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
