My Amana lwa30bw washer will trip the gfci, it has burned contacts in timer. is this common?
  • Kevin Barka Jan 03, 2013
    The burned contacts in the timer are my concern. Is this a cause or an affect
    Sergeant:
  • 291 Answers
My experience is that yeah, it's fairly common. The high speed spin contactor is usually the first to go. Though some blackness around the high speed spin contacts seem to be normal, the contacts themselves are usually ok unless they start to look pretty flat and splashy. However it usually only results in a no-spin situation, it really shouldn't cause a fault interupt. Still on one occasion, if memory serves, i have seen contacts weld together that did cause a breaker trip.
Posted on Jan 03, 2013
    Thank you for your input. I'll get a new timer and give it a try. I think the gfci may just be weak.
3 Suggested Answers
machinetech7
  • 1344 Answers
SOURCE: tripping GFCI
If the machine is tripping that outlet I would run a cord and try it on another outlet to see what happens. If it works fine then your outlet is going bad, If it trips the new outlet you're going to have a short somewhere in the machine, more than likely dealing with the motor and motor control board
Posted on Jun 16, 2012
  • 192 Answers
SOURCE: fisher and paykel trips gfci
probably ur pump.How old is it?kijji u prob find used washer cheap
Posted on Aug 12, 2012
Fuse f21 what does it do. It keeps tripping out about every four weeks How can i fix this problem
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
Apr 16, 2017 | Washing Machines
Hi lg washer dryer combo trips safety switch as soon as plugged in and wall turned on
Jan 03, 2017 | LG Washing Machines
Admiral washer. Did load of laundry, breaker tripped, and is still full of water. Reset breaker, and hear a small click after I pull knob to restart washer. Breaker trips. No leak, and outlet is good
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
May 22, 2015 | Admiral Washing Machines
When put on a wash it trips the electric
May 10, 2015 | Miele Washing Machines
Deawoo washing machin when start spin timer will triped elecricity
The washer tripped the breaker once and after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Mar 28, 2015 | Daewoo Dryers
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
I got 2 wascomat gen5 that trips breakers only on rinse cycle
WDD960 washer dryer trips the RCD when it is plugged in even when the machine is not running. Is the answer a new machine or can it be fixed
Feb 21, 2015 | Dryers
LG Tromm washer tripped breaker, now won't come on at all
Jan 06, 2014 | LG WM0642H Front Load
Frigidaire freezer quits running
actionsnax please remove the freezer from the GFCI. What is happening on this old unit is that if the compressor shuts off then tries to come back on before the pressure in the system equalizes, the compressor can pull 12 amps. This is normally higher than the trip point of the GFCI. I had this happen years ago with a brand new Amana SXS refrig, in that case no one knew the unit was on a GFCI. The manufactures require that this units not be on a GFCI.
Hope this helps
Feb 01, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
