Question about Reddy Heater-30-55,000 BTU Variable
Reddy R50 the heater puts out strong fumes
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
When heater starts up it puffs fumes then lites
Generally, if the heater puffs fumes at start up it is because there is not instantaneous combustion.
What causes this?
  1. Worn nozzle
  2. Incorrect (click for instructions) air pump pressure
  3. Spark plug carboned
  4. fuel filter restricted
  5. Air leak or vac leak between the pump and the nozzle
Generally speaking, if the fuel is being delivered as a FOG not a SPRAY, and the spark is strong and properly oriented there will be immediate combustion at start-up.
Nov 14, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a protemp 38,00 btu heater.It runs but the fuel fumes are to strong to use.How do I fix this...
This type of heater is meant to be used in a ventilated area. The fumes will build up if you are in a closed area and it will soon become overpowering. This can also be dangerous from poisonous gases. Take heed to the warning label on the unit. It probably states use in a well ventilated area.
Hope that helps you.
Jan 27, 2011 | Heating & Cooling
Were do you check for a filter? Heater is letting out fume.
heatman101
Nov 07, 2010 | Reddy R155D Utility Heater
Fumes escaping from ac vents inside vehicle while driving and leaves a film residue on inside of windshield whenever the heat or defrost are used.
Hello dedunwoodie.
Your heater core is beginning to leak coolant.
As the fan blows through it it is picking up the liquid and depositing it on your windshield.
It will need to be replaced to solve your problem.
Mar 10, 2010 | 1999 Dodge Ram
Bad odor, burning eyes from fumes.
It sounds as though some Plastic part is being heated up to Fuming Point, being melted, and releasing toxic gas, I would advise not using it until you can get it looked at by a professional.
Feb 20, 2010 | Procom ML300HGA Heater
Reddy Heater-30-55,000 BTU Variable Logo
280 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
