Is there a reset button? Nothing happens when the button is switched on. I have tried another socket but same.
1) Copy following link for troubleshooting garbage disposal, with links for manuals and tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) Red reset button is located on bottom of unit
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: leaking and then it stoped working
You may want to buy one with a 6 or 10 year warranty. If you have a ISE Pro install it you will get another 2 years warranty on the 6 yr model. That is 8 year of in-home, 100% parts and labor warranty.
Testimonial: "This is what I eventually did. Price a little higher. But if I have a problem now I know Im covered."
SOURCE: insinkerator
The capacitor is probably bad, that's what makes it start to rotate. It's under the metal case on the side of the motor. Pull it off and take it to a motor to to replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: garbage insinkerator is jammed . We tried the
The reset button pops when the GD is stuck. Do you know where the allen wrench is that came with it? If not, you need one. This goes directly in the bottom of the GD....turn it clockwise and counter clockwise to free the blades. Hit the reset and turn it on. Good luck
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
SOURCE: Insinkerator badger 5: plate rotates
Hi, The motor has gone bad heatman101
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
