Have model 310aav036070adja bryant payne furnace & has a code 33 what can cause the code
Burners will come on and stay lit for about 3 minutes then will turn off and blower works as it should and cools down sensor and then it turns off as soon as blower turns off 10 seconds later the burner turns back on and 40 seconds later the blower turns on and unit will work for about 3 minutes and then the above mentioned continues until thermostat setting is reached. it sets a code 33 after vthe first shut down occurs
Therinnaiguy
  • 1420 Answers
SOURCE: Honeywell Gas Furnace
A Make and Model number of the furnace not the thermostat will help but I can walk you thru the operation of a typical furnace. It sounds to me that the burners are igniting properly but the flame sensor is not sensing the flame and shutting down the system. You will need to find the sensor and clean it and check the wire from it to the control board. Typically, the flame sensor is found at one side or the other of the burner box. It is a small probe that the flame hits. Depending upon your model it may have a small wire attached to it leading back to the control. Or it may be part of your auto-pilot assembly. ? At any rate, you will need to get to it and very delicately brush it off. Then inspect the flame channel. This is a trough area where the flame travels to ignite all burners. Over time, they tend to fill with rust and debris. Take a small screwdriver and run the blade down the trough. Inspect the wire that goes from the flame sensor to the control board. Make sure it is not frayed or broken or shorting out and that the connection at the board is good.
Beyond that, it's time for a technician to come.
Let us know the Make and Model of the furnace (found inside the furnace cabinet) and maybe we can help you further.
Posted on Nov 20, 2007
JetJedi221
  • 25 Answers
SOURCE: The furnace burners won't stay lit
Could be a couple things. First and easiest is to check your intake combustion air supply. If it is blocked by anything or just not enough flow, it will put out the flame. Next would be the flame sensor, usually a temperature probe near the flame front. If it's not reading an increase in temp within a pre-programmed time, it will kill the flame. It can be checked with a multimeter.
Posted on Jan 25, 2008
  • 21 Answers
SOURCE: carrier model 58sxa080-gg series 100
the flame detector rod is dirty? try cleaning with sand paper and scraping also. there should be a small amp. reading threw wire coming from flame detector rod. in milli amp range. increases when running. some times i use a jumper to hold gas valve on once started to allow time to test amps.
Posted on Feb 21, 2008
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
  • 1015 Answers
SOURCE: gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Posted on Dec 21, 2009
Testimonial: "I did not expect such a quick response. These are hard times for us and we really appreciate your help. Thankyou for sharing your expertise."
3 amp fuse blows when call for gas after pilot runs for 30 seconds
check the blower motor for seized of burnt out. Fuses blow because of excess current draw and in this case if the fan is not starting everything will stop. The gas will be set so that if the fan is not running the gas will not be allowed to turn on
Nov 21, 2014 | GE Carrier Bryant Payne 1/3 Hp 115v Blower...
Per landlord, need to light pilot
You would smell the gas, so you're probably ok. Lighting the pilot is not too tough, first you have to get the cover off the furnace. Inside you will see pipes and parts. Hopefully on the cover, inside or out, or somewhere inside the furnace will be instructions.
If not, find a knob that has 'pilot', 'off' and 'run' or something like that. It will probably be in 'run'.
Usually, you have to push the knob down and turn it to get it to the 'pilot' spot. When you do, have something to lite the pilot, which will be inside the furnace more, near the burner. The burner looks like a gas stove or oven burner. The pilot place will be at the end of a small tube.
With the button held down, wave something burning around the burner area. especially at what may be the pilot. The pilot doesn't put out much gas, so don't worry about things blowing up.
Once the pilot has lit, hold the button down for a while, at least a minute. Then you should be able to release the button and the pilot should stay on. If it doesn't, you need a serviceman to come. Let the landlord know the pilot would not stay lit.
If the pilot stays lit, move the knob to 'run' or such, and the furnace should lite, if the thermostat is set higher than room temp. If it has been off, and the room is cool, it should lite.
If the furnace doesn't come on, let the landlord know.
Most landlords have service people for this, it was my job for a long time. Lighting pilots was a common chore for me. If you can, have the landlord send one out to show you how to do it.
As you see, it's not all tough, but it's not all easy, either.
Nov 29, 2013 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
I have a Rheem Criterion II Gas Furnace that has been acting up the last couple of days. It is model #RGPH-12EARJR. It will cycle on, ignite the pilot, 4 burners light and stay lit from 5-10 seconds then...
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Apr 04, 2010 | Heating & Cooling
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
My Ruud Furnace wont stay lit
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
Nov 15, 2008 | Kitchen Appliances - Others
Why Wont My Bryant Furnace Stay Running
Look on the blower door panel in the wiring diagram there should be a flash code but it sounds like the flame sensor is not picking up the flame and you may be able to clean it
Oct 28, 2008 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
