Question about NTT DoCoMo,Inc. FOMA M702iG
Omakase lock UNLOCK - NTT DoCoMo,Inc. FOMA M702iG
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Chevy Equinox Driver & Passenger Door Unlock Relay. How To Remove & Install. They Are Power Locks. Front Doors Must Roll Windows Down Use Hand To Open Thanks. Ms. J. C.
Door Lock and Unlock Operation
When a door lock switch is activated in the lock or unlock position the BCM will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuit(s) to battery positive voltage. This will energize the appropriate lock or unlock relay(s). The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the lock. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Your door locks are controlled by the BCM - body control module (a computer ) . An a scan tool is a must to diagnose system operation . Your best bet would be to take your vehicle to a qualified repair shop . The only way you could try to fix this is by changing parts ! Suppose you find an replace a door lock/ unlock relay an that doesn't fix it ? There could be DTC'S stored in the BCM . Do you know what a DTC is ?
DTC B3132 All Door Unlock Circuit Low
DTC B3133 All Door Unlock Circuit High
Your
Aug 10, 2016 | Cars & Trucks
Door lock dont always work
What door lock doesn't always work ? One or all of them . This is a complex set up for these door locks ! The switch is an input to the BCM - body control module . There is logic involved in the microprocessor , there are relays built in to the BCM ! Could have a DTC - diagnostic trouble code stored in the BCM ! Could be a bad connection at the BCM or master window switch ! A bad ground !
The power door lock system consists of the following components:
DOOR LKS fuse
Driver door lock actuator
GMLAN serial data link
Keyless entry transmitter
Passenger door lock actuator
Passenger door lock switch
Remote control door lock receiver (RCDLR)
The DR LCK fuse supplies battery voltage to the body control module (BCM) for the power door lock system. The BCM supplies and monitors a reference voltage to the driver and passenger door lock switches through the door lock switch lock/unlock signal circuit. Each door lock switch receives ground at G300 which is also the ground for the door lock and unlock relays located in the BCM. When a door lock switch is placed in the lock position, the reference voltage is switched to ground and the BCM senses 0.0 volts on the door lock/unlock signal circuit. When a door lock switch is placed in the unlock position, the reference voltage is switched to ground through a 1.5k ohm resistor that is internal to each of the door lock switches and the BCM senses approximately 2.9 volts on the door lock/unlock signal circuit. The BCM interprets what position the activated door lock switch was placed in based on the voltage drop.
The BCM, upon receipt of a lock or unlock switch signal, will switch the appropriate door lock/unlock relay coil control circuit to ground causing the appropriate door lock/unlock relay to energize. With the relay energized, voltage is applied to the door lock actuator control circuit causing the door to either lock, or unlock depending on what command was received from the power door lock switch or remote control door lock receiver (RCDLR). When a power door lock/unlock relay is not energized, the switch contacts are normally grounded through the BCM which provides ground to the appropriate door lock actuator for the lock/unlock function being performed. The power door lock/unlock functions are performed by reversing the flow of voltage through the door lock actuator control circuits. The BCM has three internal drivers for the power door lock system. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked separately from the passenger door. For additional information concerning keyless entry, refer to Keyless Entry System Description and Operation.
This is one you may want to take to dealer or some other ASE certified repair shop ! To do this right you need a Tech 2 scan tool !
Ignition ON, observe the scan tool Door Lock Switch parameter while using the driver and passenger door lock switches. The parameter should change from Idle to Lock and Unlock.
If the value does not change, refer to Door Lock Switch Malfunction.
Command the doors to LOCK and UNLOCK with the scan tool, the door lock actuators should LOCK and UNLOCK when changing between the commanded states.
If one or more doors do not LOCK or UNLOCK, refer to Door Lock Malfunction.
Aug 12, 2015 | 2009 Pontiac Solstice Convertible
Why won't the passenger door unlock?
An automatic door lock or unlock actuation
A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation.
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K?© resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
I'll post a youtube video on how to test the power door locks computer controlled , check it out ! Your problem could be a switch or the lock actuator , BCM , wiring etc.... you need to test it to see !
I'll
How to test computer controlled door locks
Mar 22, 2014 | 2008 Saturn Aura
Door locks
Replace the door panel switch on the driver side
Mar 15, 2017 | Pontiac G5 Cars & Trucks
Unlocking omakase lock on my phone
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jan 03, 2013 | Cell Phones
How to unlock cellphone with omakase lock?
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
Aug 15, 2012 | Panasonic Ntt Docomo P905i Viera Gold
Tried to unlock the phone to many times and it got locked
What is Mobile PHONE brand and Model?
You have tried how many times?whether it's locked to security code or Network locked,Because Network unlock means the unlock tries may differ from brand to brand for example Nokia has 5 tries....If you missed means you cannot unlock it,because it will get hard locked ,it locked to Network means you can unlock it using the UNLOCK CODE,It locked Security means you can unlock it using the master reset code,You have not missed the tries means it's NOKIA or samsung,LG some branded Phones means you can get the Network unlock code from here www.unlock-free.com and Unlock it,it asks for security lock means you can get the master reset code for Nokia or alcatel Phone there and unlock it...You cannot unlock it's hard locked means...You can only flash it ....
Sep 27, 2011 | Cell Phones
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Computers & Internet Logo
49 people viewed this question
Top NTT DoCoMo,Inc. Computers & Internet Experts
Are you a NTT DoCoMo,Inc. Computer and Internet Expert? Answer questions, earn points and help others
